Dear experts recently I had a small problem when running the program, while running I emitted 50 particles. During the run, the terminal keeps outputting messages and it looks like the program is working properly, but after less than a minute the program stops and the terminal shows that the program is killed.
I first thought it was a problem with my program, so I ran the B5 example directly and fired 50 particles as well, at which point the same problem occurred as mentioned earlier.
So I would like to ask you experts if this problem is related to the configuration of the computer, and if it is also related to the visualization of the program that I have enabled when I run it.
Thank you, experts, your replies will be very helpful to me.
Thanks for your reply, I am using G411.0 and as you said I am using/run/beamOn 50.
I’m running the program on VMware using a Linux system.
The main information I output is the position of the particle, and the x, y ,z of the particle in SD is output in the terminal.
The following is my output information:
G4WT3 > x = 0.127487 y = 0.182981 z = 10.6057
G4WT0 > x = -0.175801 y = -0.109594 z = 6.015
G4WT3 > -------DicomSD::ProcessHits-------
G4WT0 > -------DicomSD::ProcessHits-------
G4WT3 > x = 0.127127 y = 0.183145 z = 10.5283
G4WT0 > x = -0.175801 y = -0.109593 z = 6.01544
G4WT3 > x = 0.12743 y = 0.183521 z = 10.5284
G4WT0 > x = -0.175738 y = -0.109563 z = 6.06495
G4WT3 > x = 0.127614 y = 0.184201 z = 10.5285
G4WT0 > x = -0.17567 y = -0.10928 z = 6.19402
G4WT0 > x = -0.17568 y = -0.109327 z = 6.24132
G4WT0 > x = -0.175692 y = -0.109422 z = 6.29009
G4WT3 > x = 0.128161 y = 0.183292 z = 10.5286
G4WT0 > x = -0.175695 y = -0.109458 z = 6.32934
G4WT0 > x = -0.175276 y = -0.109431 z = 6.49982
G4WT3 > x = 0.126086 y = 0.183238 z = 10.3807
G4WT0 > x = -0.17512 y = -0.109771 z = 6.60785
G4WT3 > x = 0.125415 y = 0.183125 z = 10.2821
G4WT0 > x = -0.175083 y = -0.109911 z = 6.64319
G4WT3 > x = 0.113904 y = 0.182214 z = 10.2869
G4WT0 > x = -0.175076 y = -0.109927 z = 6.64717
G4WT3 > x = 0.0851866 y = 0.149547 z = 10.3211
G4WT0 > x = -0.17499 y = -0.110102 z = 6.68715
I only intercepted part of the output because the output of these messages is normal until the program crashes, all similar to these messages I posted here.
When the program crashes this message will appear.
G4WT1 > x = -1.14739 y = -1.84515 z = 12.6843
G4WT2 > x = -0.268086 y = -0.0491451 z = 14.5333
G4WT0 > x = -0.182013 y = -0.137419 z = 9.56238
G4WT1 > -------DicomSD::ProcessHits-------
G4WT2 > -------DicomSD::ProcessHits-------
G4WT3 > x = -0.609542 y = 0.156716 z = 15.6547
killed
This time I also turned on the visualization and used the QT GUI tool.
Hi Allison
Thanks for your reply, I think you might be right, because this problem also occurs when I test the sample code. This should indicate that it is not a code issue.
