I am encountering strange problem after I created new release for Synchtrotron Radiation (SR) simulation using Geant4-10.1.2.
Is the UI command to activate SR still the same :
‘/physics_engine/tailor/SyncRadiation on’ ?
In my script I use it like this :
sync = 1
if sync :
simulation.param(‘UICommands’,[’/physics_engine/tailor/SyncRadiation on’,’/process/list’])
and I do not see SynRad in the list of processes. Even though I see in the list of simulation parameters that UI command is accepted.
With the former release with Geant4-9.6.2 I had used it the same way and it worked well.
Just to be sure that the command is still the same and maybe I have to look more carefully for
some other reason in my release.
I had a close look into Geant4 10.1p03 and do see this command available. You need to have G4EmExtraPhysics (it is used by default in all reference Physics Lists). The command to activate synchrotron should be before /run/initialise
Thank you.
I found it myself that the Available G4_States for old and new commands are different.
I think that is the reason.
Unfortunately I run the simulation not in Standalone Geant4 but in a mainframe. Somehow I didnt get
error messages about “Illegal G4_State”.
Everything is fine with Geant4 and I have to find out a solution myself .
I guess this item can be marked as solved or deleted .
