ThibFe
September 28, 2021, 9:18am
#1
Hi everyone,
Until now, I made a various simulations with an empty sphere on which I subtracted various cylinder and box at different angle to make holes into it. But when I tried to increase one (box) hole (which is subtracted multiple times) by 1cm, the compilation is going well however when I launch the OGL visualization I end with a black screen.
Any suggestions are welcome
Thanks
Thibault
allison
September 28, 2021, 11:44am
#2
What version of Geant4 are you using? Are there any warning messages?
ThibFe
September 28, 2021, 12:38pm
#3
I’m using the 10.07-p02 and I don’t have any messages. The visualization stay black and in my console I have the end of my Vis.mac file (I tried to reduce or change it but the problem is still here)
allison
September 28, 2021, 4:41pm
#4
I’m sorry, but will you look back through your console messages. I would be very surprised if there is not some clue to the problem in there.
Please give as much detail as possible when filing a problem. What platform are you running on? What build configuration?
ThibFe
September 29, 2021, 12:58pm
#5
Nothing special appear on my console, I have the exact same console output as when I simulate smaller holes.
And like the only change between these 2 simulation is the size of the subtracted volume, I suspect it to be at fault here. But there are no errors that occur when compiling or launching.
Otherwise I’m running it on ubuntu 18.04.6 LTS and it was build whith cmake 3.10.2 …
Available UI session types: [ Qt, GAG, tcsh, csh ]
Geant4 version Name: geant4-10-07-patch-02 [MT] (11-June-2021)
<< in Multi-threaded mode >>
: IEEE-TNS 53 (2006), 270-278
: NIM A 835 (2016), 186-225
WWW : http://geant4.org/
<<< Geant4 Physics List simulation engine: QGSP_BIC_HP
### G4HadronElasticPhysics: hElasticWEL_CHIPS_LEND
### G4HadronElasticPhysicsLEND: hElasticWEL_CHIPS_LEND
G4VModularPhysicsList::ReplacePhysics: hElasticWEL_CHIPS_HP with type : 5 is replaced with hElasticWEL_CHIPS_LEND
G4VModularPhysicsList::ReplacePhysics: hInelastic QGSP_BIC_HP with type : 6 is replaced with hInelastic ShieldingLEND
test 1
Using Root
ASCIITree (ATree)
DAWNFILE (DAWNFILE)
G4HepRep (HepRepXML)
G4HepRepFile (HepRepFile)
RayTracer (RayTracer)
VRML1FILE (VRML1FILE)
VRML2FILE (VRML2FILE)
gMocrenFile (gMocrenFile)
OpenGLImmediateX (OGLIX, OGLIQt_FALLBACK)
OpenGLStoredX (OGLSX, OGLSQt_FALLBACK)
Registered model factories:
generic
drawByAttribute
drawByCharge
drawByOriginVolume
drawByParticleID
drawByEncounteredVolume
Registered models:
None
Registered filter factories:
attributeFilter
chargeFilter
originVolumeFilter
particleFilter
encounteredVolumeFilter
Registered filters:
None
/control/saveHistory
/run/verbose 1
/run/numberOfThreads 14
/run/initialize
Construction géometrie...
distance detecteur 200: 565.301 cm
Géometrie complète
### HadronElasticPhysics::ConstructProcess: Elimit for for anti-neuclei 0.1 GeV for all hadrons Emax(GeV)= 100000
Dumping UsedTarget of LENDElastic for neutron
Requested Evaluation, Z , A -> Actual Evaluation, Z , A(0=Nat)
**Initialization of the physic list**
G4WT11 > Using Root
G4WT11 > /control/saveHistory
G4WT11 > /run/initialize
G4WT11 > /run/physicsModified
/control/execute vis.mac
/vis/open OGL
/vis/drawVolume
/tracking/storeTrajectory 2
"/vis/modeling/trajectories/create/drawByAttribute" and
"/vis/filtering/trajectories/create/attributeFilter" commands:
G4TrajectoriesModel:
Event ID (EventID): G4int
Run ID (RunID): G4int
G4SmoothTrajectory:
Track ID (ID): G4int
No. of points (NTP): G4int
PDG Encoding (PDG): G4int
Parent ID (PID): G4int
Particle Name (PN): G4String
G4SmoothTrajectoryPoint:
WARNING: Trajectory storing has been requested. This action may be
reversed with "/tracking/storeTrajectory 0".
/vis/scene/notifyHandlers
/vis/modeling/trajectories/create/drawByParticleID
/vis/modeling/trajectories/drawByParticleID-0/default/setDrawStepPts true
/vis/modeling/trajectories/drawByParticleID-0/set neutron blue
WARNING: The vis manager will keep up to 100 events.
This may use a lot of memory.
It may be changed with, e.g., "/vis/scene/endOfEventAction accumulate 10".
/vis/viewer/refresh
/vis/verbose warnings
/vis/viewer/flush
/gps/source/clear
/gps/source/add 1
/gps/particle neutron
/gps/ene/type Mono
/gps/ene/mono 4. MeV
/gps/pos/type Point
/gps/pos/centre 0. 0. 0. cm
/gps/ang/type iso
/gps/ang/minphi 149 deg
/gps/ang/maxphi 157 deg
/gps/ang/mintheta 98 deg
/gps/ang/maxtheta 106 deg
weller
September 29, 2021, 1:15pm
#6
this might be a stupid question: have you checked that you do not somehow subtract the complete volume and simply nothing is left over? to increase the “box hole by 1cm” could also mean that the whole box is 2cm by 2cm by 2cm larger, as dimensions in geant4 are typically half-lengths. depending on how large it was before, this could be quite significant
otherwise you probably need to post some code…
ThibFe
September 29, 2021, 1:58pm
#7
The mother value is a sphere whose diameter is about 1m , the part I want to remove is a box of 3*3cm (formerly 2 by 2 cm) with a length about twice the thickness of the sphere (which stay unchanged).
On the old simulation, the visualization doesn’t show any problems ans there is plenty of place for increasing the hole size.
