Hello everyone!
I am trying to impose step limits and cuts on a specific region and I get a Break segmentation violation problem. I must say that imposing limits and cuts directly on a logical volume does not cause any troubles in my code.
So, in my PhysicsList.cc file, I do the following:
void PhysicsList::SetDosimetryCuts()
//Forcing low-energy limit for production
G4ProductionCutsTable::GetProductionCutsTable() ->SetEnergyRange(100*eV, 100.*GeV);
G4String regionName = "stepLimitRegion2";
G4Region* Detregion = G4RegionStore::GetInstance()->GetRegion(regionName);
G4ProductionCuts* cuts = new G4ProductionCuts();
cuts -> SetProductionCut(0.001*mm,"gamma");
cuts -> SetProductionCut(0.001*mm,"e-");
cuts -> SetProductionCut(0.001*mm,"e+");
G4double stepMax = 1*um;
G4double trackMax = 1*um;
G4UserLimits* limits = new G4UserLimits();
limits -> SetMaxAllowedStep(stepMax);
limits -> SetUserMaxTrackLength(trackMax);
if(Detregion)
Detregion -> SetProductionCuts(cuts);
Detregion -> SetUserLimits(limits);
G4cout << "### stepLimitRegion2 gamma production cut = " << G4BestUnit(Detregion->GetProductionCuts()->GetProductionCut("gamma"), "Length") << G4endl;
else
G4cout << "### G4Region with name " << regionName << " not found" << G4endl;
While in my DetectorConstruction.cc file I have the following code (where I create a region with two logical volumes):
stepLimitRegion2 = new G4Region("stepLimitRegion2");
Active_logic->SetRegion(stepLimitRegion2);
stepLimitRegion2->AddRootLogicalVolume(Active_logic);
sensitive_logic->SetRegion(stepLimitRegion2);
stepLimitRegion2->AddRootLogicalVolume(sensitive_logic);
The Break Segmentation violation occurs when I add the AddRootLogicalVolume lines:
When I remove them, the code runs but step limits/cuts are not assigned. I guess I may be using the Region designation in the DetectorConstruction.cc in a wrong way…
Any ideas? Thanks!
Vasily
