I’m trying to bias a Cf-252 radioactive decay simulation to boost the spontaneous fission rate. When I try
/grdm/BRbias 1
I get the error:
command </grdm/BRbias 1> not found
I can see this command in the source code I built, but quite a few grdm
commands do not show up in the help
Command directory path : /grdm/
Guidance :
Controls for the Radioactive Decay Module.
Sub-directories :
Commands :
1) nucleusLimits * Set the atomic weight and number limits for the RDM.
2) selectVolume * Suppply a logical volumes name to add it to the RDM apply list
3) deselectVolume * Suppply a logical volumes name to remove it from the RDM apply list
4) allVolumes * apply RDM to all logical volumes. No parameter required.
5) noVolumes * RDM is not applied to any logical volumes
6) applyICM * Command not active; kept for backward compatibility.
7) applyARM * True: ARM is applied; false: no
8) decayDirection * Supply the direction vector for decay products
9) decayHalfAngle * Supply maximum angle from direction vector for decay products
10) verbose * Set verbose level: 0, 1, 2 or 3
11) setRadioactiveDecayFile * Supply user-defined radioactive decay data file
12) setPhotoEvaporationFile * Supply user-defined photon evaporation data file
Any ideas what could be going wrong?
Alternatively, is there an easy way to set the spontaneous fission branching ratio of my Cf-252 to 100%?
