Given that we are studying two close resonance, we are currently studying them separately (i.e. one time we launch the simulation using the values for the first resonance, one time using values of the second one), then we have to replace each time the
with the correct files for the for the resonance that we are studying.
Due to the fact that we are 4 people working to the simulation (we run it on laboratory machine) when I launch the simulation, I’ve to advice the other 3 people do not change the rescap10_21 and z11.a22 untill I end my simulation (and they must do the same).
I would know where are these files called? Because I would write (if possible) a messenger file so that in the run.mac we can write a flag to call the wanted file.
For example we will have
and in those directories, do the appropriate file replacement to match the directory name.
Now, when each of the five people on your team runs, they set those two envvars to point to the particular version they want (maybe set up your own shell scripts to take care of it). You don’t have to coordinate changing a single central directory. Everybody can be running simultaneously with different configurations.
The down side is that those envvironment variable settings aren’t saved as part of the Geant4 output log. You’ll have to keep track of it separately to know the provenance of the different outputs.
