Hello @weller truly, the previous graph refered to a carbon target (I used it for a fast simulation probe). On the contrary, to compare simulation-data results I must use a tungsten target and this is the plot of track id
as you can see…in this case, the number of trackID is higher than in the probe using the carbon.
I modified the code retriving the secondaries
for(size_t lp1=0;lp1<(*fSecondary).size(); lp1++){
secondaryParticleName = (*fSecondary)[lp1]->GetDefinition() -> GetParticleName(); // name of the secondary
process = (*fSecondary)[lp1]-> GetCreatorProcess()-> GetProcessName(); // process creating it
fSectrackID = (*fSecondary)[lp1]->GetTrackID(); //track id
fSsecparID = (*fSecondary)[lp1]->GetParentID(); //parent id
volumeName = (*fSecondary)[lp1] -> GetVolume() -> GetName(); // volume where secondary was generated
if(volume==fScoringVolumeScint) {
int pdg = step->GetTrack()->GetParticleDefinition()->GetPDGEncoding();
analysisManager->FillNtupleDColumn(9,0, pdg);
int trackID = step->GetTrack()->GetTrackID();
analysisManager->FillNtupleDColumn(9,1, trackID);
int evtID = evt->GetEventID();
analysisManager->FillNtupleDColumn(9,2, evtID);
int parID = step->GetTrack()->GetParentID();
analysisManager->FillNtupleDColumn(9,3, parID);
double partEdep = step->GetTotalEnergyDeposit();
analysisManager->FillNtupleDColumn(9,4, partEdep);
analysisManager->AddNtupleRow(9);
following this message of @guatelli Energy Deposited from Secondary Particle in RadioProtection Class but I always get the energy for each step instead of for each secondary particle…
