Different result for low energy between G4 11.0.0 and G4 10.7.0
I simulated X-ray spectrum from a target sample by e- irradiation.
I use Penelope physics models.
But I got different spectra between G4 11.0.0 and G4 10.7.0. in the same source code.
I set min energy with 100 eV by
/cuts/setLowEdge 100 eV
and
G4ProductionCutsTable::GetProductionCutsTable()->SetEnergyRange(100 * eV, 1 * MeV);
G4 11.0.0 does not detect x-ray lower than 1 keV. G4 10.7 can detect this x-ray.
spec
EmParameter is
G4EmParameters* emParameters = G4EmParameters::Instance();
emParameters->SetAugerCascade(true);
emParameters->SetFluo(true);
emParameters->SetPixe(true);
emParameters->SetAuger(true);
I don’t know why these are different.
Please help.
Thanks.
try to use
emParameters->SetDeexcitationIgnoreCut(true);
and/or
emParameters->SetLowestElectronEnergy(10*eV);
VI
Thanks civanch.
I tried to use
G4 11.0.0 detects Fluoro. lines but do not detect Bremss. less than 1 keV (See red line).
spec
does not change the result.
Do you have other solution or try?
Thanks a lot.
Please, try
after "/run/initilise and Physics List is constructed, and before “/run/beamOn N”
VI
I set
And after execute “/run/initialize” before “/run/beamOn N”.
In my case,
is described in the constructor of MyPhysicsList class.
Vladimir
Where do I write
I write this in the construction of PhysicsList, normaly.
I try to write in the ConstructProcess in PhysicsList, but my results is without Bremss. below 1 keV.
Hi
I try to use G4EMLOW7.13 on Geant4 11.0.0.
I can get the same result as Geant4 10.7.0.
Is there some problem or specification change in G4EMLOW8.0?
Can I use G4EMLOW7.13 on Geant4 11.0.0?
Thanks.
