Hi all,
So I’m trying to use an ASCII/csv file in my GPS macro file. Everything is all good to go aside from this one additional piece. I’m gonna copy and paste the core dump/the ascii file itself.
THanks so much if you can help!
mucho bueno!
Geant4 version Name: geant4-10-05-patch-01 (17-April-2019)
: IEEE-TNS 53 (2006), 270-278
: NIM A 835 (2016), 186-225
WWW : http://geant4.org/
Registering graphics systems…
Current available graphics systems are:
ASCIITree (ATree)
DAWNFILE (DAWNFILE)
G4HepRep (HepRepXML)
G4HepRepFile (HepRepFile)
RayTracer (RayTracer)
VRML1FILE (VRML1FILE)
VRML2FILE (VRML2FILE)
gMocrenFile (gMocrenFile)
Registering model factories…
Registered model factories:
generic
drawByAttribute
drawByCharge
drawByOriginVolume
drawByParticleID
drawByEncounteredVolume
Registered filter factories:
attributeFilter
chargeFilter
originVolumeFilter
particleFilter
encounteredVolumeFilter
“/vis/list” to see available colours.
Checking overlaps for volume FrontWall1 … OK!
Checking overlaps for volume FrontWall2 … OK!
Checking overlaps for volume RightWall … OK!
Checking overlaps for volume LeftWall … OK!
Checking overlaps for volume BackWall … OK!
Checking overlaps for volume TopWall … OK!
Checking overlaps for volume BottomWall … OK!
Checking overlaps for volume PbFW … OK!
Checking overlaps for volume PbBW … OK!
Checking overlaps for volume PbRW … OK!
Checking overlaps for volume PbLW … OK!
Checking overlaps for volume PbTW … OK!
Checking overlaps for volume PbBottom … OK!
Checking overlaps for volume WATER … OK!
Issue /vis/viewer/refresh or flush to see effect.
/tracking/storeTrajectory 1
G4TrajectoriesModel:
Event ID (EventID): G4int
Run ID (RunID): G4int
G4Trajectory:
Track ID (ID): G4int
No. of points (NTP): G4int
PDG Encoding (PDG): G4int
Parent ID (PID): G4int
Particle Name (PN): G4String
G4TrajectoryPoint:
Position (Pos): G4BestUnit (G4ThreeVector)
WARNING: Trajectory storing has been requested. This action may be
reversed with “/tracking/storeTrajectory 0”.
G4VisManager: Using G4TrajectoryDrawByCharge as fallback trajectory model.
See commands in /vis/modeling/trajectories/ for other options.
HepRepFile writing to G4Data0.heprep
/run/verbose 1
/event/verbose 1
/tracking/verbose 1
/gps/verbose 1
/gps/particle gamma
/gps/pos/type Volume
/gps/pos/shape Sphere
/gps/pos/confine World
Volume World exists
/gps/pos/centre 0 0 0 cm
/gps/pos/radius 816 cm
/gps/ang/type iso
/gps/ene/type User
/gps/hist/file ChemLabSNO.csv
*** G4Exception : Event0301
issued by : G4SPSEneDistribution::ArbEnergyHistoFile
Unable to open the histo ASCII file
Aborted (core dumped)
Here is the ASCII file, sorry in advance it is very long… The bin width is 29ish KeV all the way up to 30 MeV. Do I need to convert the KeV right to MeV?
Energy Bin (MeV) | Weight |
0 | 0 |
29.3112 | 2.93112 |
29.3112 | 5.86224 |
29.3112 | 17.58672 |
29.3112 | 2063.50848 |
29.3112 | 5812.41096 |
29.3112 | 5023.93968 |
29.3112 | 3687.34896 |
29.3112 | 4733.7588 |
29.3112 | 6638.9868 |
29.3112 | 10182.71088 |
29.3112 | 17047.39392 |
29.3112 | 24808.99968 |
29.3112 | 1868539.171 |
29.3112 | 43673688 |
29.3112 | 38397672 |
29.3112 | 35759664 |
29.3112 | 23448960 |
29.3112 | 34294104 |
29.3112 | 12955550.4 |
29.3112 | 20488528.8 |
29.3112 | 16707384 |
29.3112 | 15212512.8 |
29.3112 | 18466056 |
29.3112 | 14538355.2 |
29.3112 | 9350272.8 |
29.3112 | 7562289.6 |
29.3112 | 7239866.4 |
29.3112 | 9057160.8 |
29.3112 | 11988280.8 |
29.3112 | 11724480 |
29.3112 | 9789940.8 |
29.3112 | 7474356 |
29.3112 | 5774306.4 |
29.3112 | 4777725.6 |
29.3112 | 5657061.6 |
29.3112 | 13102106.4 |
29.3112 | 24562785.6 |
29.3112 | 20547151.2 |
29.3112 | 6155352 |
29.3112 | 842266.1254 |
29.3112 | 236787.5981 |
29.3112 | 167194.0159 |
29.3112 | 132366.4481 |
29.3112 | 104983.925 |
29.3112 | 87593.59008 |
29.3112 | 80221.82328 |
29.3112 | 80327.3436 |
29.3112 | 75728.41632 |
29.3112 | 58097.72952 |
29.3112 | 42334.16616 |
29.3112 | 36726.9336 |
29.3112 | 34751.35872 |
29.3112 | 29827.07712 |
29.3112 | 26289.21528 |
29.3112 | 24249.15576 |
29.3112 | 21845.63736 |
29.3112 | 18932.10408 |
29.3112 | 17170.50096 |
29.3112 | 15552.52272 |
29.3112 | 12181.73472 |
29.3112 | 8778.7044 |
29.3112 | 6891.06312 |
29.3112 | 6120.17856 |
29.3112 | 4771.86336 |
29.3112 | 4129.94808 |
29.3112 | 3866.14728 |
29.3112 | 3792.86928 |
29.3112 | 4915.48824 |
29.3112 | 6378.11712 |
29.3112 | 6111.3852 |
29.3112 | 5566.19688 |
29.3112 | 5167.56456 |
29.3112 | 5428.43424 |
29.3112 | 6354.66816 |
29.3112 | 7172.45064 |
29.3112 | 8104.5468 |
29.3112 | 9171.47448 |
29.3112 | 9634.59144 |
29.3112 | 9414.75744 |
29.3112 | 9241.82136 |
29.3112 | 7746.95016 |
29.3112 | 6817.78512 |
29.3112 | 6164.14536 |
29.3112 | 5689.30392 |
29.3112 | 3464.58384 |
29.3112 | 1345.38408 |
29.3112 | 688.8132 |
29.3112 | 507.08376 |
29.3112 | 486.56592 |
29.3112 | 592.08624 |
29.3112 | 565.70616 |
29.3112 | 630.1908 |
29.3112 | 618.46632 |
29.3112 | 612.60408 |
29.3112 | 621.39744 |
29.3112 | 680.01984 |
29.3112 | 738.64224 |
29.3112 | 700.53768 |
29.3112 | 697.60656 |
29.3112 | 808.98912 |
29.3112 | 788.47128 |
29.3112 | 823.64472 |
29.3112 | 820.7136 |
29.3112 | 847.09368 |
29.3112 | 718.1244 |
29.3112 | 794.33352 |
29.3112 | 732.78 |
29.3112 | 732.78 |
29.3112 | 665.36424 |
29.3112 | 627.25968 |
29.3112 | 583.29288 |
29.3112 | 577.43064 |
29.3112 | 574.49952 |
29.3112 | 539.32608 |
29.3112 | 510.01488 |
29.3112 | 524.67048 |
29.3112 | 504.15264 |
29.3112 | 483.6348 |
29.3112 | 466.04808 |
29.3112 | 436.73688 |
29.3112 | 425.0124 |
29.3112 | 422.08128 |
29.3112 | 416.21904 |
29.3112 | 413.28792 |
29.3112 | 395.7012 |
29.3112 | 401.56344 |
29.3112 | 407.42568 |
29.3112 | 404.49456 |
29.3112 | 410.3568 |
29.3112 | 430.87464 |
29.3112 | 439.668 |
29.3112 | 442.59912 |
29.3112 | 448.46136 |
29.3112 | 451.39248 |
29.3112 | 454.3236 |
29.3112 | 457.25472 |
29.3112 | 460.18584 |
29.3112 | 463.11696 |
29.3112 | 468.9792 |
29.3112 | 471.91032 |
29.3112 | 474.84144 |
29.3112 | 477.77256 |
29.3112 | 480.70368 |
29.3112 | 489.49704 |
29.3112 | 492.42816 |
29.3112 | 495.35928 |
29.3112 | 498.2904 |
29.3112 | 501.22152 |
29.3112 | 512.946 |
29.3112 | 515.87712 |
29.3112 | 518.80824 |
29.3112 | 521.73936 |
29.3112 | 527.6016 |
29.3112 | 530.53272 |
29.3112 | 533.46384 |
29.3112 | 536.39496 |
29.3112 | 542.2572 |
29.3112 | 545.18832 |
29.3112 | 548.11944 |
29.3112 | 551.05056 |
29.3112 | 553.98168 |
29.3112 | 556.9128 |
29.3112 | 559.84392 |
29.3112 | 562.77504 |
29.3112 | 568.63728 |
29.3112 | 571.5684 |
29.3112 | 580.36176 |
29.3112 | 586.224 |
29.3112 | 589.15512 |
29.3112 | 595.01736 |
29.3112 | 597.94848 |
29.3112 | 600.8796 |
29.3112 | 603.81072 |
29.3112 | 606.74184 |
29.3112 | 609.67296 |
29.3112 | 615.5352 |
29.3112 | 624.32856 |
29.3112 | 633.12192 |
29.3112 | 636.05304 |
29.3112 | 638.98416 |
29.3112 | 641.91528 |
29.3112 | 644.8464 |
29.3112 | 647.77752 |
29.3112 | 650.70864 |
29.3112 | 653.63976 |
29.3112 | 656.57088 |
29.3112 | 659.502 |
29.3112 | 662.43312 |
29.3112 | 668.29536 |
29.3112 | 671.22648 |
29.3112 | 674.1576 |
29.3112 | 677.08872 |
29.3112 | 682.95096 |
29.3112 | 685.88208 |
29.3112 | 691.74432 |
29.3112 | 694.67544 |
29.3112 | 703.4688 |
29.3112 | 706.39992 |
29.3112 | 709.33104 |
29.3112 | 712.26216 |
29.3112 | 715.19328 |
29.3112 | 721.05552 |
29.3112 | 723.98664 |
29.3112 | 726.91776 |
29.3112 | 729.84888 |
29.3112 | 732.78 |
29.3112 | 735.71112 |
29.3112 | 741.57336 |
29.3112 | 744.50448 |
29.3112 | 747.4356 |
29.3112 | 750.36672 |
29.3112 | 753.29784 |
29.3112 | 756.22896 |
29.3112 | 759.16008 |
29.3112 | 762.0912 |
29.3112 | 765.02232 |
29.3112 | 767.95344 |
29.3112 | 770.88456 |
29.3112 | 773.81568 |
29.3112 | 776.7468 |
29.3112 | 779.67792 |
29.3112 | 782.60904 |
29.3112 | 785.54016 |
29.3112 | 791.4024 |
29.3112 | 797.26464 |
29.3112 | 800.19576 |
29.3112 | 803.12688 |
29.3112 | 806.058 |
29.3112 | 811.92024 |
29.3112 | 814.85136 |
29.3112 | 817.78248 |
29.3112 | 826.57584 |
29.3112 | 829.50696 |
29.3112 | 832.43808 |
29.3112 | 835.3692 |
29.3112 | 838.30032 |
29.3112 | 841.23144 |
29.3112 | 844.16256 |
29.3112 | 850.0248 |
29.3112 | 852.95592 |
29.3112 | 855.88704 |
29.3112 | 858.81816 |
29.3112 | 861.74928 |
29.3112 | 864.6804 |
29.3112 | 867.61152 |
29.3112 | 870.54264 |
29.3112 | 873.47376 |
29.3112 | 876.40488 |
29.3112 | 879.336 |
29.3112 | 882.26712 |
29.3112 | 885.19824 |
29.3112 | 888.12936 |
29.3112 | 891.06048 |
29.3112 | 893.9916 |
29.3112 | 896.92272 |
29.3112 | 899.85384 |
29.3112 | 902.78496 |
29.3112 | 905.71608 |
29.3112 | 908.6472 |
29.3112 | 911.57832 |
29.3112 | 914.50944 |
29.3112 | 917.44056 |
29.3112 | 920.37168 |
29.3112 | 923.3028 |
29.3112 | 926.23392 |
29.3112 | 929.16504 |
29.3112 | 932.09616 |
29.3112 | 935.02728 |
29.3112 | 937.9584 |
29.3112 | 940.88952 |
29.3112 | 943.82064 |
29.3112 | 946.75176 |
29.3112 | 949.68288 |
29.3112 | 952.614 |
29.3112 | 955.54512 |
29.3112 | 958.47624 |
29.3112 | 961.40736 |
29.3112 | 964.33848 |
29.3112 | 967.2696 |
29.3112 | 970.20072 |
29.3112 | 973.13184 |
29.3112 | 976.06296 |
29.3112 | 978.99408 |
29.3112 | 981.9252 |
29.3112 | 984.85632 |
29.3112 | 987.78744 |
29.3112 | 990.71856 |
29.3112 | 993.64968 |
29.3112 | 996.5808 |
29.3112 | 999.51192 |
29.3112 | 1002.44304 |
29.3112 | 1005.37416 |
29.3112 | 1008.30528 |
29.3112 | 1011.2364 |
29.3112 | 1014.16752 |
29.3112 | 1017.09864 |
29.3112 | 1020.02976 |
29.3112 | 1022.96088 |
29.3112 | 1025.892 |
29.3112 | 1028.82312 |
29.3112 | 1031.75424 |
29.3112 | 1034.68536 |
29.3112 | 1037.61648 |
29.3112 | 1040.5476 |
29.3112 | 1043.47872 |
29.3112 | 1046.40984 |
29.3112 | 1049.34096 |
29.3112 | 1052.27208 |
29.3112 | 1055.2032 |
29.3112 | 1058.13432 |
29.3112 | 1061.06544 |
29.3112 | 1063.99656 |
29.3112 | 1066.92768 |
29.3112 | 1069.8588 |
29.3112 | 1072.78992 |
29.3112 | 1075.72104 |
29.3112 | 1078.65216 |
29.3112 | 1081.58328 |
29.3112 | 1084.5144 |
29.3112 | 1087.44552 |
29.3112 | 1090.37664 |
29.3112 | 1093.30776 |
29.3112 | 1096.23888 |
29.3112 | 1099.17 |
29.3112 | 1102.10112 |
29.3112 | 1105.03224 |
29.3112 | 1107.96336 |
29.3112 | 1110.89448 |
29.3112 | 1113.8256 |
29.3112 | 1116.75672 |
29.3112 | 1119.68784 |
29.3112 | 1122.61896 |
29.3112 | 1125.55008 |
29.3112 | 1128.4812 |
29.3112 | 1131.41232 |
29.3112 | 1134.34344 |
29.3112 | 1137.27456 |
29.3112 | 1140.20568 |
29.3112 | 1143.1368 |
29.3112 | 1146.06792 |
29.3112 | 1148.99904 |
29.3112 | 1151.93016 |
29.3112 | 1154.86128 |
29.3112 | 1157.7924 |
29.3112 | 1160.72352 |
29.3112 | 1163.65464 |
29.3112 | 1166.58576 |
29.3112 | 1169.51688 |
29.3112 | 1172.448 |
29.3112 | 1175.37912 |
29.3112 | 1178.31024 |
29.3112 | 1181.24136 |
29.3112 | 1184.17248 |
29.3112 | 1187.1036 |
29.3112 | 1190.03472 |
29.3112 | 1192.96584 |
29.3112 | 1195.89696 |
29.3112 | 1198.82808 |
29.3112 | 1201.7592 |
29.3112 | 1204.69032 |
29.3112 | 1207.62144 |
29.3112 | 1210.55256 |
29.3112 | 1213.48368 |
29.3112 | 1216.4148 |
29.3112 | 1219.34592 |
29.3112 | 1222.27704 |
29.3112 | 1225.20816 |
29.3112 | 1228.13928 |
29.3112 | 1231.0704 |
29.3112 | 1234.00152 |
29.3112 | 1236.93264 |
29.3112 | 1239.86376 |
29.3112 | 1242.79488 |
29.3112 | 1245.726 |
29.3112 | 1248.65712 |
29.3112 | 1251.58824 |
29.3112 | 1254.51936 |
29.3112 | 1257.45048 |
29.3112 | 1260.3816 |
29.3112 | 1263.31272 |
29.3112 | 1266.24384 |
29.3112 | 1269.17496 |
29.3112 | 1272.10608 |
29.3112 | 1275.0372 |
29.3112 | 1277.96832 |
29.3112 | 1280.89944 |
29.3112 | 1283.83056 |
29.3112 | 1286.76168 |
29.3112 | 1289.6928 |
29.3112 | 1292.62392 |
29.3112 | 1295.55504 |
29.3112 | 1298.48616 |
29.3112 | 1301.41728 |
29.3112 | 1304.3484 |
29.3112 | 1307.27952 |
29.3112 | 1310.21064 |
29.3112 | 1313.14176 |
29.3112 | 1316.07288 |
29.3112 | 1319.004 |
29.3112 | 1321.93512 |
29.3112 | 1324.86624 |
29.3112 | 1327.79736 |
29.3112 | 1330.72848 |
29.3112 | 1333.6596 |
29.3112 | 1336.59072 |
29.3112 | 1339.52184 |
29.3112 | 1342.45296 |
29.3112 | 1348.3152 |
29.3112 | 1351.24632 |
29.3112 | 1354.17744 |
29.3112 | 1357.10856 |
29.3112 | 1360.03968 |
29.3112 | 1362.9708 |
29.3112 | 1365.90192 |
29.3112 | 1368.83304 |
29.3112 | 1371.76416 |
29.3112 | 1374.69528 |
29.3112 | 1377.6264 |
29.3112 | 1380.55752 |
29.3112 | 1383.48864 |
29.3112 | 1386.41976 |
29.3112 | 1389.35088 |
29.3112 | 1392.282 |
29.3112 | 1395.21312 |
29.3112 | 1398.14424 |
29.3112 | 1401.07536 |
29.3112 | 1404.00648 |
29.3112 | 1406.9376 |
29.3112 | 1409.86872 |
29.3112 | 1412.79984 |
29.3112 | 1415.73096 |
29.3112 | 1418.66208 |
29.3112 | 1421.5932 |
29.3112 | 1424.52432 |
29.3112 | 1427.45544 |
29.3112 | 1430.38656 |
29.3112 | 1433.31768 |
29.3112 | 1436.2488 |
29.3112 | 1439.17992 |
29.3112 | 1442.11104 |
29.3112 | 1445.04216 |
29.3112 | 1447.97328 |
29.3112 | 1450.9044 |
29.3112 | 1453.83552 |
29.3112 | 1456.76664 |
29.3112 | 1459.69776 |
29.3112 | 1462.62888 |
29.3112 | 1465.56 |
29.3112 | 1468.49112 |
29.3112 | 1471.42224 |
29.3112 | 1474.35336 |
29.3112 | 1477.28448 |
29.3112 | 1480.2156 |
29.3112 | 1483.14672 |
29.3112 | 1486.07784 |
29.3112 | 1489.00896 |
29.3112 | 1491.94008 |
29.3112 | 1494.8712 |
29.3112 | 1497.80232 |
29.3112 | 1500.73344 |
29.3112 | 1503.66456 |
29.3112 | 1506.59568 |
29.3112 | 1509.5268 |
29.3112 | 1512.45792 |
29.3112 | 1515.38904 |
29.3112 | 1518.32016 |
29.3112 | 1521.25128 |
29.3112 | 1524.1824 |
29.3112 | 1527.11352 |
29.3112 | 1530.04464 |
29.3112 | 1532.97576 |
29.3112 | 1535.90688 |
29.3112 | 1538.838 |
29.3112 | 1541.76912 |
29.3112 | 1544.70024 |
29.3112 | 1547.63136 |
29.3112 | 1550.56248 |
29.3112 | 1553.4936 |
29.3112 | 1556.42472 |
29.3112 | 1559.35584 |
29.3112 | 1562.28696 |
29.3112 | 1565.21808 |
29.3112 | 1568.1492 |
29.3112 | 1571.08032 |
29.3112 | 1574.01144 |
29.3112 | 1576.94256 |
29.3112 | 1579.87368 |
29.3112 | 1582.8048 |
29.3112 | 1585.73592 |
29.3112 | 1588.66704 |
29.3112 | 1591.59816 |
29.3112 | 1594.52928 |
29.3112 | 1597.4604 |
29.3112 | 1600.39152 |
29.3112 | 1603.32264 |
29.3112 | 1606.25376 |
29.3112 | 1609.18488 |
29.3112 | 1612.116 |
29.3112 | 1615.04712 |
29.3112 | 1617.97824 |
29.3112 | 1620.90936 |
29.3112 | 1623.84048 |
29.3112 | 1626.7716 |
29.3112 | 1629.70272 |
29.3112 | 1632.63384 |
29.3112 | 1635.56496 |
29.3112 | 1638.49608 |
29.3112 | 1641.4272 |
29.3112 | 1644.35832 |
29.3112 | 1647.28944 |
29.3112 | 1650.22056 |
29.3112 | 1653.15168 |
29.3112 | 1656.0828 |
29.3112 | 1659.01392 |
29.3112 | 1661.94504 |
29.3112 | 1664.87616 |
29.3112 | 1667.80728 |
29.3112 | 1670.7384 |
29.3112 | 1673.66952 |
29.3112 | 1676.60064 |
29.3112 | 1679.53176 |
29.3112 | 1682.46288 |
29.3112 | 1685.394 |
29.3112 | 1688.32512 |
29.3112 | 1691.25624 |
29.3112 | 1694.18736 |
29.3112 | 1697.11848 |
29.3112 | 1700.0496 |
29.3112 | 1702.98072 |
29.3112 | 1705.91184 |
29.3112 | 1708.84296 |
29.3112 | 1711.77408 |
29.3112 | 1714.7052 |
29.3112 | 1717.63632 |
29.3112 | 1720.56744 |
29.3112 | 1723.49856 |
29.3112 | 1726.42968 |
29.3112 | 1729.3608 |
29.3112 | 1732.29192 |
29.3112 | 1735.22304 |
29.3112 | 1738.15416 |
29.3112 | 1741.08528 |
29.3112 | 1744.0164 |
29.3112 | 1746.94752 |
29.3112 | 1749.87864 |
29.3112 | 1752.80976 |
29.3112 | 1755.74088 |
29.3112 | 1758.672 |
29.3112 | 1761.60312 |
29.3112 | 1764.53424 |
29.3112 | 1767.46536 |
29.3112 | 1770.39648 |
29.3112 | 1773.3276 |
29.3112 | 1776.25872 |
29.3112 | 1779.18984 |
29.3112 | 1782.12096 |
29.3112 | 1785.05208 |
29.3112 | 1787.9832 |
29.3112 | 1790.91432 |
29.3112 | 1793.84544 |
29.3112 | 1796.77656 |
29.3112 | 1799.70768 |
29.3112 | 1802.6388 |
29.3112 | 1805.56992 |
29.3112 | 1808.50104 |
29.3112 | 1811.43216 |
29.3112 | 1814.36328 |
29.3112 | 1817.2944 |
29.3112 | 1820.22552 |
29.3112 | 1823.15664 |
29.3112 | 1826.08776 |
29.3112 | 1829.01888 |
29.3112 | 1831.95 |
29.3112 | 1834.88112 |
29.3112 | 1837.81224 |
29.3112 | 1840.74336 |
29.3112 | 1843.67448 |
29.3112 | 1846.6056 |
29.3112 | 1849.53672 |
29.3112 | 1852.46784 |
29.3112 | 1855.39896 |
29.3112 | 1858.33008 |
29.3112 | 1861.2612 |
29.3112 | 1864.19232 |
29.3112 | 1867.12344 |
29.3112 | 1870.05456 |
29.3112 | 1872.98568 |
29.3112 | 1875.9168 |
29.3112 | 1878.84792 |
29.3112 | 1881.77904 |
29.3112 | 1884.71016 |
29.3112 | 1887.64128 |
29.3112 | 1890.5724 |
29.3112 | 1893.50352 |
29.3112 | 1896.43464 |
29.3112 | 1899.36576 |
29.3112 | 1902.29688 |
29.3112 | 1905.228 |
29.3112 | 1908.15912 |
29.3112 | 1911.09024 |
29.3112 | 1914.02136 |
29.3112 | 1916.95248 |
29.3112 | 1919.8836 |
29.3112 | 1922.81472 |
29.3112 | 1925.74584 |
29.3112 | 1928.67696 |
29.3112 | 1931.60808 |
29.3112 | 1934.5392 |
29.3112 | 1937.47032 |
29.3112 | 1940.40144 |
29.3112 | 1943.33256 |
29.3112 | 1946.26368 |
29.3112 | 1949.1948 |
29.3112 | 1952.12592 |
29.3112 | 1955.05704 |
29.3112 | 1957.98816 |
29.3112 | 1960.91928 |
29.3112 | 1963.8504 |
29.3112 | 1966.78152 |
29.3112 | 1969.71264 |
29.3112 | 1972.64376 |
29.3112 | 1975.57488 |
29.3112 | 1978.506 |
29.3112 | 1981.43712 |
29.3112 | 1984.36824 |
29.3112 | 1987.29936 |
29.3112 | 1990.23048 |
29.3112 | 1993.1616 |
29.3112 | 1996.09272 |
29.3112 | 1999.02384 |
29.3112 | 2001.95496 |
29.3112 | 2004.88608 |
29.3112 | 2007.8172 |
29.3112 | 2010.74832 |
29.3112 | 2013.67944 |
29.3112 | 2016.61056 |
29.3112 | 2019.54168 |
29.3112 | 2022.4728 |
29.3112 | 2025.40392 |
29.3112 | 2028.33504 |
29.3112 | 2031.26616 |
29.3112 | 2034.19728 |
29.3112 | 2037.1284 |
29.3112 | 2040.05952 |
29.3112 | 2042.99064 |
29.3112 | 2045.92176 |
29.3112 | 2048.85288 |
29.3112 | 2051.784 |
29.3112 | 2054.71512 |
29.3112 | 2057.64624 |
29.3112 | 2060.57736 |
29.3112 | 2066.4396 |
29.3112 | 2069.37072 |
29.3112 | 2072.30184 |
29.3112 | 2075.23296 |
29.3112 | 2078.16408 |
29.3112 | 2081.0952 |
29.3112 | 2084.02632 |
29.3112 | 2086.95744 |
29.3112 | 2089.88856 |
29.3112 | 2092.81968 |
29.3112 | 2095.7508 |
29.3112 | 2098.68192 |
29.3112 | 2101.61304 |
29.3112 | 2104.54416 |
29.3112 | 2107.47528 |
29.3112 | 2110.4064 |
29.3112 | 2113.33752 |
29.3112 | 2116.26864 |
29.3112 | 2119.19976 |
29.3112 | 2122.13088 |
29.3112 | 2125.062 |
29.3112 | 2127.99312 |
29.3112 | 2130.92424 |
29.3112 | 2133.85536 |
29.3112 | 2136.78648 |
29.3112 | 2139.7176 |
29.3112 | 2142.64872 |
29.3112 | 2145.57984 |
29.3112 | 2148.51096 |
29.3112 | 2151.44208 |
29.3112 | 2154.3732 |
29.3112 | 2157.30432 |
29.3112 | 2160.23544 |
29.3112 | 2163.16656 |
29.3112 | 2166.09768 |
29.3112 | 2169.0288 |
29.3112 | 2171.95992 |
29.3112 | 2174.89104 |
29.3112 | 2177.82216 |
29.3112 | 2180.75328 |
29.3112 | 2183.6844 |
29.3112 | 2186.61552 |
29.3112 | 2189.54664 |
29.3112 | 2192.47776 |
29.3112 | 2195.40888 |
29.3112 | 2198.34 |
29.3112 | 2201.27112 |
29.3112 | 2204.20224 |
29.3112 | 2207.13336 |
29.3112 | 2210.06448 |
29.3112 | 2212.9956 |
29.3112 | 2215.92672 |
29.3112 | 2218.85784 |
29.3112 | 2221.78896 |
29.3112 | 2224.72008 |
29.3112 | 2227.6512 |
29.3112 | 2230.58232 |
29.3112 | 2233.51344 |
29.3112 | 2236.44456 |
29.3112 | 2239.37568 |
29.3112 | 2242.3068 |
29.3112 | 2245.23792 |
29.3112 | 2248.16904 |
29.3112 | 2251.10016 |
29.3112 | 2254.03128 |
29.3112 | 2256.9624 |
29.3112 | 2259.89352 |
29.3112 | 2262.82464 |
29.3112 | 2265.75576 |
29.3112 | 2268.68688 |
29.3112 | 2271.618 |
29.3112 | 2274.54912 |
29.3112 | 2277.48024 |
29.3112 | 2280.41136 |
29.3112 | 2283.34248 |
29.3112 | 2286.2736 |
29.3112 | 2289.20472 |
29.3112 | 2292.13584 |
29.3112 | 2295.06696 |
29.3112 | 2297.99808 |
29.3112 | 2300.9292 |
29.3112 | 2303.86032 |
29.3112 | 2306.79144 |
29.3112 | 2309.72256 |
29.3112 | 2312.65368 |
29.3112 | 2315.5848 |
29.3112 | 2318.51592 |
29.3112 | 2321.44704 |
29.3112 | 2324.37816 |
29.3112 | 2327.30928 |
29.3112 | 2330.2404 |
29.3112 | 2333.17152 |
29.3112 | 2336.10264 |
29.3112 | 2339.03376 |
29.3112 | 2341.96488 |
29.3112 | 2344.896 |
29.3112 | 2347.82712 |
29.3112 | 2350.75824 |
29.3112 | 2353.68936 |
29.3112 | 2356.62048 |
29.3112 | 2359.5516 |
29.3112 | 2362.48272 |
29.3112 | 2365.41384 |
29.3112 | 2368.34496 |
29.3112 | 2371.27608 |
29.3112 | 2374.2072 |
29.3112 | 2377.13832 |
29.3112 | 2380.06944 |
29.3112 | 2383.00056 |
29.3112 | 2385.93168 |
29.3112 | 2388.8628 |
29.3112 | 2391.79392 |
29.3112 | 2394.72504 |
29.3112 | 2397.65616 |
29.3112 | 2400.58728 |
29.3112 | 2403.5184 |
29.3112 | 2406.44952 |
29.3112 | 2409.38064 |
29.3112 | 2412.31176 |
29.3112 | 2415.24288 |
29.3112 | 2418.174 |
29.3112 | 2421.10512 |
29.3112 | 2424.03624 |
29.3112 | 2426.96736 |
29.3112 | 2429.89848 |
29.3112 | 2432.8296 |
29.3112 | 2435.76072 |
29.3112 | 2438.69184 |
29.3112 | 2441.62296 |
29.3112 | 2444.55408 |
29.3112 | 2447.4852 |
29.3112 | 2450.41632 |
29.3112 | 2453.34744 |
29.3112 | 2456.27856 |
29.3112 | 2459.20968 |
29.3112 | 2462.1408 |
29.3112 | 2465.07192 |
29.3112 | 2468.00304 |
29.3112 | 2470.93416 |
29.3112 | 2473.86528 |
29.3112 | 2476.7964 |
29.3112 | 2479.72752 |
29.3112 | 2482.65864 |
29.3112 | 2485.58976 |
29.3112 | 2488.52088 |
29.3112 | 2491.452 |
29.3112 | 2494.38312 |
29.3112 | 2497.31424 |
29.3112 | 2500.24536 |
29.3112 | 2503.17648 |
29.3112 | 2506.1076 |
29.3112 | 2509.03872 |
29.3112 | 2511.96984 |
29.3112 | 2514.90096 |
29.3112 | 2517.83208 |
29.3112 | 2520.7632 |
29.3112 | 2523.69432 |
29.3112 | 2526.62544 |
29.3112 | 2529.55656 |
29.3112 | 2532.48768 |
29.3112 | 2535.4188 |
29.3112 | 2538.34992 |
29.3112 | 2541.28104 |
29.3112 | 2544.21216 |
29.3112 | 2547.14328 |
29.3112 | 2550.0744 |
29.3112 | 2553.00552 |
29.3112 | 2555.93664 |
29.3112 | 2558.86776 |
29.3112 | 2561.79888 |
29.3112 | 2564.73 |
29.3112 | 2567.66112 |
29.3112 | 2570.59224 |
29.3112 | 2573.52336 |
29.3112 | 2576.45448 |
29.3112 | 2579.3856 |
29.3112 | 2582.31672 |
29.3112 | 2585.24784 |
29.3112 | 2588.17896 |
29.3112 | 2591.11008 |
29.3112 | 2594.0412 |
29.3112 | 2596.97232 |
29.3112 | 2599.90344 |
29.3112 | 2602.83456 |
29.3112 | 2605.76568 |
29.3112 | 2608.6968 |
29.3112 | 2611.62792 |
29.3112 | 2614.55904 |
29.3112 | 2617.49016 |
29.3112 | 2620.42128 |
29.3112 | 2623.3524 |
29.3112 | 2626.28352 |
29.3112 | 2629.21464 |
29.3112 | 2632.14576 |
29.3112 | 2635.07688 |
29.3112 | 2638.008 |
29.3112 | 2640.93912 |
29.3112 | 2643.87024 |
29.3112 | 2646.80136 |
29.3112 | 2649.73248 |
29.3112 | 2652.6636 |
29.3112 | 2655.59472 |
29.3112 | 2658.52584 |
29.3112 | 2661.45696 |
29.3112 | 2664.38808 |
29.3112 | 2667.3192 |
29.3112 | 2670.25032 |
29.3112 | 2673.18144 |
29.3112 | 2676.11256 |
29.3112 | 2679.04368 |
29.3112 | 2681.9748 |
29.3112 | 2684.90592 |
29.3112 | 2687.83704 |
29.3112 | 2690.76816 |
29.3112 | 2693.69928 |
29.3112 | 2696.6304 |
29.3112 | 2699.56152 |
29.3112 | 2702.49264 |
29.3112 | 2705.42376 |
29.3112 | 2708.35488 |
29.3112 | 2711.286 |
29.3112 | 2714.21712 |
29.3112 | 2717.14824 |
29.3112 | 2720.07936 |
29.3112 | 2723.01048 |
29.3112 | 2725.9416 |
29.3112 | 2728.87272 |
29.3112 | 2731.80384 |
29.3112 | 2734.73496 |
29.3112 | 2737.66608 |
29.3112 | 2740.5972 |
29.3112 | 2743.52832 |
29.3112 | 2746.45944 |
29.3112 | 2749.39056 |
29.3112 | 2752.32168 |
29.3112 | 2755.2528 |
29.3112 | 2758.18392 |
29.3112 | 2761.11504 |
29.3112 | 2764.04616 |
29.3112 | 2766.97728 |
29.3112 | 2769.9084 |
29.3112 | 2772.83952 |
29.3112 | 2775.77064 |
29.3112 | 2778.70176 |
29.3112 | 2781.63288 |
29.3112 | 2784.564 |
29.3112 | 2787.49512 |
29.3112 | 2790.42624 |
29.3112 | 2793.35736 |
29.3112 | 2796.28848 |
29.3112 | 2799.2196 |
29.3112 | 2802.15072 |
29.3112 | 2805.08184 |
29.3112 | 2808.01296 |
29.3112 | 2810.94408 |
29.3112 | 2813.8752 |
29.3112 | 2816.80632 |
29.3112 | 2819.73744 |
29.3112 | 2822.66856 |
29.3112 | 2825.59968 |
29.3112 | 2828.5308 |
29.3112 | 2831.46192 |
29.3112 | 2834.39304 |
29.3112 | 2837.32416 |
29.3112 | 2840.25528 |
29.3112 | 2843.1864 |
29.3112 | 2846.11752 |
29.3112 | 2849.04864 |
29.3112 | 2851.97976 |
29.3112 | 2854.91088 |
29.3112 | 2857.842 |
29.3112 | 2860.77312 |
29.3112 | 2863.70424 |
29.3112 | 2866.63536 |
29.3112 | 2869.56648 |
29.3112 | 2872.4976 |
29.3112 | 2875.42872 |
29.3112 | 2878.35984 |
29.3112 | 2881.29096 |
29.3112 | 2884.22208 |
29.3112 | 2887.1532 |
29.3112 | 2890.08432 |
29.3112 | 2893.01544 |
29.3112 | 2895.94656 |
29.3112 | 2898.87768 |
29.3112 | 2901.8088 |
29.3112 | 2904.73992 |
29.3112 | 2907.67104 |
29.3112 | 2910.60216 |
29.3112 | 2913.53328 |
29.3112 | 2916.4644 |
29.3112 | 2919.39552 |
29.3112 | 2922.32664 |
29.3112 | 2925.25776 |
29.3112 | 2928.18888 |
29.3112 | 2931.12 |
29.3112 | 2934.05112 |
29.3112 | 2936.98224 |
29.3112 | 2939.91336 |
29.3112 | 2942.84448 |
29.3112 | 2945.7756 |
29.3112 | 2948.70672 |
29.3112 | 2951.63784 |
29.3112 | 2954.56896 |
29.3112 | 2957.50008 |
29.3112 | 2960.4312 |
29.3112 | 2963.36232 |
29.3112 | 2966.29344 |
29.3112 | 2969.22456 |
29.3112 | 2972.15568 |
29.3112 | 2975.0868 |
29.3112 | 2978.01792 |
29.3112 | 2980.94904 |
29.3112 | 2983.88016 |
29.3112 | 2986.81128 |
29.3112 | 2989.7424 |
29.3112 | 2992.67352 |
29.3112 | 2995.60464 |
29.3112 | 2998.53576 |
