I have a question regarding the G4TScoreNtupleWriter: can it work with a G4VSensitiveDetector subclass like in the B2 example or does it only work with the combination of G4MultiFunctionalDetector and G4VPrimitiveScorer like in example B3? If it does, what do I need to adapt in the B2 example to make the G4TScoreNtupleWriter work?
G4TScoreNtupleWriter performs storing hits collections of G4THitsMap; which are registered to G4Event hits collections. So if user defined in his own sensitive detector a hit collection of this type, G4TScoreNtupleWriter should be able to handle them.
It cannot be used with a user defined hits of user type; in this case, you have to use G4Analysis ntuples directly.
