Hello there,
I am using Geant4-v10.1 and I am trying to create a new generator in this big simulation for a big collaboration.
At this moment, I was able to create a new generator called “CustomEvt” which I needed for simulating two primaries, a neutron and a gamma.
Now, I want to read the neutron energy from a file called “neutron_spectrum.txt” that looks like this:
0.0 0.004183350400822896
0.01 0.0061559115469339894
0.02 0.007854697778009402
0.03 0.009467939925478
0.04 0.011116145382421989
0.05 0.012739389686657263
0.06 0.014277726005035818
0.07 0.01573603243530642
0.08 0.017280354048559564
0.09 0.01869268961789877
0.1 0.020057977701304144
0.11 0.021349977251555744
0.12 0.02267589182256974
0.13 0.023924753927035195
0.14 0.025105372035072307
0.15 0.026255454673943062
0.16 0.027368129542818653
0.17 0.028384116633618263
etc
Where the weights are normalized between 0 and 1 and energy goes up to almost 10 MeV.
For this, I am trying to do the following:
// Create the energy distribution object
G4SPSEneDistribution* energyDist = new G4SPSEneDistribution();
// Set the energy distribution from a file
energyDist->SetEnergyDisType("Arb");
energyDist->ArbEnergyHistoFile("/Users/diiego/software/wcsim_replacement/build/neutron_spectrum.txt");
// Obtain the definition of the neutron and sample an energy from the distribution
G4ParticleTable* particleTable = G4ParticleTable::GetParticleTable();
G4ParticleDefinition* neutronDefinition = particleTable->FindParticle("neutron");
// Sample an energy for the neutron
G4double nEnergy = energyDist->GenerateOne(neutronDefinition);
But when I add the G4double nEnergy = energyDist->GenerateOne(neutronDefinition);
line, application crashes when running it, even though it compiles correctly. Here the output of the crash:
Geant4 version Name: geant4-10-01-patch-03 (5-February-2016)
Reference : NIM A 506 (2003), 250-303
WWW : http://cern.ch/geant4
Setting water attenuation parameter 1.300000
Setting cathode reflectivity parameter 0.320000
Setting Rayleigh scattering parameter 0.750000
Setting blacksheet reflection parameter 2.500000
Setting Mie scattering parameter 0.000000
Setting Top Veto Off
Setting Top Veto PMT Spacing 100.000000
There are 20 available physics lists, and they are:
FTFP_BERT
FTFP_BERT_TRV
FTFP_BERT_HP
FTFP_INCLXX
FTFP_INCLXX_HP
FTF_BIC
LBE
QBBC
QGSP_BERT
QGSP_BERT_HP
QGSP_BIC
QGSP_BIC_HP
QGSP_FTFP_BERT
QGSP_INCLXX
QGSP_INCLXX_HP
QGS_BIC
Shielding
ShieldingLEND
ShieldingM
NuBeam
Setting Physics list to FTFP_BERT and delaying initialization
Setting neutron capture model to Default
Initializing physics list FTFP_BERT
G4PhysListFactory::GetReferencePhysList <FTFP_BERT> EMoption= 0
<<< Geant4 Physics List simulation engine: FTFP_BERT 2.0
<<< Reference Physics List FTFP_BERT is built
RegisterPhysics: G4EmStandard
RegisterPhysics: G4GammaLeptoNuclearPhys
RegisterPhysics: Decay
RegisterPhysics: hElasticWEL_CHIPS
RegisterPhysics: hInelastic FTFP_BERT
RegisterPhysics: stopping
RegisterPhysics: ionInelasticFTFP_BIC
RegisterPhysics: neutronTrackingCut
RegisterPhysics: OpticalPhysics
You have successfully chosen to use the following graphics systems.
Current available graphics systems are:
ASCIITree (ATree)
DAWNFILE (DAWNFILE)
G4HepRep (HepRepXML)
G4HepRepFile (HepRepFile)
OpenGLImmediateQt (OGLIQt)
OpenGLStoredQt (OGLSQt)
RayTracer (RayTracer)
VRML1FILE (VRML1FILE)
VRML2FILE (VRML2FILE)
ASCIITree (ATree)
DAWNFILE (DAWNFILE)
G4VisManager: No model factories registered with G4VisManager.
G4VisManager::RegisterModelFactories() should be overridden in derived
class. See G4VisExecutive for an example.
Registered model factories:
None
Registered models:
Unspecified (Current)
Registered filter factories:
None
Available colours:
black, blue, brown, cyan, gray, green, grey, magenta, red, white, yellow
Digitizer choice set to SKI (this is a default set; it may be overwritten by user commands)
Trigger choice set to NDigits (this is a default set; it may be overwritten by user commands)
Saving only triggered events (this is a default set; it may be overwritten by user commands)
Trigger time for events which fail all triggers will be set to 100 ns (this is a default set; it may be overwritten by user commands)
SaveFailures pretrigger window set to -400 ns (this is a default set; it may be overwritten by user commands)
SaveFailures posttrigger window set to 950 ns (this is a default set; it may be overwritten by user commands)
Will adjust NDigits trigger threshold using average dark noise rate (this is a default set; it may be overwritten by user commands)
Setting DarkMode value 0 (this is a default set; it may be overwritten by user commands)
Setting DarkLow value 0 (this is a default set; it may be overwritten by user commands)
Setting DarkHigh value 100000 (this is a default set; it may be overwritten by user commands)
Setting DarkWindow value 5000 (this is a default set; it may be overwritten by user commands)
**** Building Cylindrical Detector ****
Computed tolerance = 4.08e-07 mm
Checking overlaps for volume WCBarrel ... OK!
Checking overlaps for volume WCBarrelAnnulus ... OK!
Checking overlaps for volume WCBarrelCellBlackSheet ... OK!
Checking overlaps for volume WCExtraTower ... OK!
Checking overlaps for volume WCExtraTowerBlackSheet ... OK!
Expose height for PMT SuperK-glassFaceWCPMT : 180 mm
Radius at expose height : 254 mm
Radius of curvature : 269.211 mm
Reflector radius : 254 mm
Reflector thickness : 0 mm
Checking overlaps for volume InteriorWCPMT ... OK!
Checking overlaps for volume SuperK-glassFaceWCPMT ... OK!
Checking overlaps for volume WCBarrelBorderRing ... OK!
Checking overlaps for volume WCExtraTowerBorderCell ... OK!
Checking overlaps for volume WCCap ... OK!
Checking overlaps for volume WCCapBlackSheet ... OK!
total on cap: 1672
Coverage was calculated to be: 0.380348
total on cap: 1672
Checking overlaps for volume TopCapAssembly ... OK!
Checking overlaps for volume BottomCapAssembly ... OK!
WCLength = 40.8 m
position Y = 0
expHallLength = 122.4
Geofile written
### Adding tracking cuts for neutron TimeCut(ns)= 10000 KinEnergyCut(MeV)= 0
WCSimPhysicsListFactory::SetCuts:CutLength : 1 mm
Available UI session types: [ Qt, GAG, tcsh, csh ]
position Y = 0
Geofile written
Warning in <TBranch::TBranch>: Extra characters after type tag 'Char_t' for branch 'GeometryType'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Double_t' for branch 'CylinderRadius'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Double_t' for branch 'CylinderLength'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Char_t' for branch 'PMTtype_ID'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Double_t' for branch 'PMTradius_ID'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Char_t' for branch 'PMTtype_OD'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Double_t' for branch 'PMTradius_OD'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Int_t' for branch 'numPMT_ID'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Int_t' for branch 'numPMT_OD'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Int_t' for branch 'Orientation'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Double_t' for branch 'Offset_x'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Double_t' for branch 'Offset_y'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Double_t' for branch 'Offset_z'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Int_t' for branch 'num_mPMT'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Int_t' for branch 'Tube'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Int_t' for branch 'mPMT'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Int_t' for branch 'mPMT_pmt'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Double_t' for branch 'x'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Double_t' for branch 'y'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Double_t' for branch 'z'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Int_t' for branch 'cylLocation'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Double_t' for branch 'direction_x'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Double_t' for branch 'direction_y'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Double_t' for branch 'direction_z'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Double_t' for branch 'phi'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Double_t' for branch 'theta'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Int_t' for branch 'Run'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Int_t' for branch 'Event'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Int_t' for branch 'SubEvent'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Int_t' for branch 'Type'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Int_t' for branch 'TriggeredDigits'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Double_t' for branch 'Length'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Double_t' for branch 'StartTime'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Int_t' for branch 'InteractionMode'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Char_t' for branch 'VertexVolume'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Double_t' for branch 'Vertex_x'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Double_t' for branch 'Vertex_y'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Double_t' for branch 'Vertex_z'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Int_t' for branch 'Ntracks'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Int_t' for branch 'Pid'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Int_t' for branch 'Flag'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Float_t' for branch 'Mass'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Float_t' for branch 'P'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Float_t' for branch 'Energy'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Int_t' for branch 'ParentID'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Int_t' for branch 'TrackID'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Float_t' for branch 'Time'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Float_t' for branch 'Dirx'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Float_t' for branch 'Diry'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Float_t' for branch 'Dirz'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Float_t' for branch 'Px'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Float_t' for branch 'Py'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Float_t' for branch 'Pz'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Float_t' for branch 'Start_x'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Float_t' for branch 'Start_y'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Float_t' for branch 'Start_z'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Float_t' for branch 'Stop_x'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Float_t' for branch 'Stop_y'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Float_t' for branch 'Stop_z'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Float_t' for branch 'Length'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Int_t' for branch 'NHits'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Int_t' for branch 'NHits_noDN'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Int_t' for branch 'NPMTs'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Int_t' for branch 'NPMTs_noDN'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Int_t' for branch 'PMT_QTot'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Int_t' for branch 'PMT_QTot_noDN'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Int_t' for branch 'Vector_index'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Float_t' for branch 'PMT_x'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Float_t' for branch 'PMT_y'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Float_t' for branch 'PMT_z'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Float_t' for branch 'PMT_dirx'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Float_t' for branch 'PMT_diry'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Float_t' for branch 'PMT_dirz'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Int_t' for branch 'NDigiHits'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Int_t' for branch 'NDigiPMTs'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Float_t' for branch 'QTotDigi'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Float_t' for branch 'Q'; must be one character.
Warning in <TBranch::TBranch>: Extra characters after type tag 'Float_t' for branch 'T'; must be one character.
*** Break *** segmentation violation
[/usr/lib/system/libsystem_platform.dylib] _sigtramp (no debug info)
[/Users/diiego/software/GEANT4/GEANT4_10.1/install/lib/libG4event.dylib] G4SPSRandomGenerator::GenRandEnergy() (no debug info)
[/Users/diiego/software/GEANT4/GEANT4_10.1/install/lib/libG4event.dylib] G4SPSEneDistribution::GenArbPointEnergies() (no debug info)
[/Users/diiego/software/GEANT4/GEANT4_10.1/install/lib/libG4event.dylib] G4SPSEneDistribution::GenerateOne(G4ParticleDefinition*) (no debug info)
[/Users/diiego/software/wcsim_replacement/build/WCSim] WCSimPrimaryGeneratorAction::GeneratePrimaries(G4Event*) (no debug info)
[/Users/diiego/software/GEANT4/GEANT4_10.1/install/lib/libG4run.dylib] G4RunManager::GenerateEvent(int) (no debug info)
[/Users/diiego/software/GEANT4/GEANT4_10.1/install/lib/libG4run.dylib] G4RunManager::ProcessOneEvent(int) (no debug info)
[/Users/diiego/software/GEANT4/GEANT4_10.1/install/lib/libG4run.dylib] G4RunManager::DoEventLoop(int, char const*, int) (no debug info)
[/Users/diiego/software/GEANT4/GEANT4_10.1/install/lib/libG4run.dylib] G4RunManager::BeamOn(int, char const*, int) (no debug info)
[/Users/diiego/software/GEANT4/GEANT4_10.1/install/lib/libG4run.dylib] G4RunMessenger::SetNewValue(G4UIcommand*, G4String) (no debug info)
[/Users/diiego/software/GEANT4/GEANT4_10.1/install/lib/libG4intercoms.dylib] G4UIcommand::DoIt(G4String) (no debug info)
[/Users/diiego/software/GEANT4/GEANT4_10.1/install/lib/libG4intercoms.dylib] G4UImanager::ApplyCommand(char const*) (no debug info)
[/Users/diiego/software/GEANT4/GEANT4_10.1/install/lib/libG4intercoms.dylib] G4UIbatch::ExecCommand(G4String const&) (no debug info)
[/Users/diiego/software/GEANT4/GEANT4_10.1/install/lib/libG4intercoms.dylib] G4UIbatch::SessionStart() (no debug info)
[/Users/diiego/software/GEANT4/GEANT4_10.1/install/lib/libG4intercoms.dylib] G4UImanager::ExecuteMacroFile(char const*) (no debug info)
[/Users/diiego/software/GEANT4/GEANT4_10.1/install/lib/libG4intercoms.dylib] G4UIcontrolMessenger::SetNewValue(G4UIcommand*, G4String) (no debug info)
[/Users/diiego/software/wcsim_replacement/build/WCSim] main (no debug info)
[/usr/lib/dyld] start (no debug info)
I suspect the error comes from not having set a G4SPSRandomGenerator. I tried and also crashes.
Maybe I should use the User
function from the SetEnergyDisType
? When I could use GPS from the macro file that controls the simulation I used the User Defined Histograms and everything worked fine and easily, but now I find this extremely confusing.
Hope you can help me, thanks in advance, Diego
