I’m trying to generate an electron-positron pair source that shoots both particles at the same time.
I’m using the G4ParticleGun class. I have to read from an external file 1000 events. For each event I have the e- energy and its momentum direction and the e+ energy with its momentum direction. I have created a vertex inside my volume and I have associated to it, like in the particleGun : PrimaryGeneratorAction1 example, the electron and the positron with the properties read from the file.
When I execute my code I have the following error:
G4EnergyRangeManager:GetHadronicInteraction: counter=2, Ek=nan, Material = Helium3, Element = helium3 *0* low=0, high=3500 *1* low=3000, high=1e+08 In /Applications/geant4.10.05/source/processes/hadronic/management/src/G4EnergyRangeManager.cc, line 128: ===> GetHadronicInteraction: No Model found -------- EEEE ------- G4Exception-START -------- EEEE ------- *** G4Exception : had005 issued by : G4HadronicProcess::PostStepDoIt In /Applications/geant4.10.05/source/processes/hadronic/management/src/G4EnergyRangeManager.cc, line 128: ===> GetHadronicInteraction: No Model found Target element helium3 Z= 2 A= 3 Unrecoverable error in the method ChooseHadronicInteraction of photonNuclear TrackID= 2006 ParentID= 1994 gamma Ekin(GeV)= nan; direction= (nan,nan,nan) Position(mm)= (nan,nan,nan); material Helium3 PhysicalVolume <Absorb_phys> No HadronicInteraction found out *** Fatal Exception *** core dump *** G4Track (0x10a075f50) - track ID = 2006, parent ID = 1994 Particle type : gamma - creator process : annihil, creator model : annihil Kinetic energy : nan eV - Momentum direction : (nan,nan,nan) Step length : 11.1734 m - total energy deposit : 0 eV Pre-step point : (nan,nan,nan) - Physical volume : Absorb_phys (Helium3) - defined by : Transportation - step status : 1 Post-step point : (nan,nan,nan) - Physical volume : Absorb_phys (Helium3) - defined by : photonNuclear - step status : 4 *** Note: Step information might not be properly updated. -------- EEEE -------- G4Exception-END --------- EEEE ------- *** G4Exception: Aborting execution *** Program ended with exit code: 9
If I substitute the e+ with a neutron I have no error.
I would really appreciated your assistance on how to implement correctly my source.
Thank you
