Error while compiling simple code for detector construction: undefined reference to `MyDetectorConstruction::DefineMaterials()
I have this error while adding the sensitive volume to the detector:
/usr/bin/ld: CMakeFiles/sim.dir/construction.cc.o: in function MyDetectorConstruction::MyDetectorConstruction()': construction.cc:(.text+0x37): undefined reference to MyDetectorConstruction::DefineMaterials()’
make[2]: *** [CMakeFiles/sim.dir/build.make:204: sim] Error 1
make[1]: *** [CMakeFiles/Makefile2:104: CMakeFiles/sim.dir/all] Error 2
make: *** [Makefile:84: all] Error 2
Can someone please help me remove it?
It looks as if you have declared a function and forgot to include the .cc file with its implementation in the CMake project.
This is my CMakeLists.txt file
cmake_minimum_required(VERSION 2.6 FATAL_ERROR)
project(Simulation)
include(${Geant4_USE_FILE})
file(GLOB sources ${PROJECT_SOURCE_DIR}/*.cc)
file(GLOB headers ${PROJECT_SOURCE_DIR}/*.hh)
add_executable(sim sim.cc ${sources} ${headers})
target_link_libraries(sim ${Geant4_LIBRARIES})
file(GLOB MACRO_FILES
  "*.mac"
file(COPY ${MACRO_FILES} DESTINATION ${PROJECT_BINARY_DIR})
file(GLOB DATA_FILES
  "*.dat"
file(COPY ${DATA_FILES} DESTINATION ${PROJECT_BINARY_DIR})
add_custom_target(Simulation DEPENDS sim)
I think I added all the .cc and .hh files.
Then check you have re-run cmake and also check in which file you implemented the method.
