Dear all,
I was using fKillTrackAndSecondaries to kill the e+ generated. But when I run it with verbosity I still see e+ is stacked and see annihilation gamma. The snippet of the code I used in SteppingAction is:
if((volume==“DetectorPhys” ) && (aStep->GetTrack()->GetDefinition()->GetParticleName() == “e+”))
if(eKin > .0 ){
G4String CPName;
if(aStep->GetTrack()->GetCreatorProcess()!=0){
CPName = aStep->GetTrack()->GetCreatorProcess()->GetProcessName();
//if(CPName == "annihil"){
std::ofstream WriteDataIn("DetectorPoistronall.txt", std::ios::app);
WriteDataIn << eKin << '\t' << " "
<< PosX << ‘\t’ << " "
<< PosY << ‘\t’ << " "
<< PosZ << ‘\t’ << " "
<< MomX << ‘\t’ << " "
<< MomY << ‘\t’ << " "
<< MomZ << ‘\t’ << " "
<< globalTime << ‘\t’ << " "
<< eventNum << '\t' << " "
<< parentID << ‘\t’ << " "
<< trackID << ‘\t’ << " "
<< CPName << '\t' << " "
<< particle << '\t' << " "
<< G4endl;
theTrack->SetTrackStatus(fKillTrackAndSecondaries);}
And in the screen I can see that :
G4WT0 > * G4Track Information: Particle = e+, Track ID = 12, Parent ID = 1
G4WT0 > *********************************************************************************************************
G4WT0 >
G4WT0 > Step# X(mm) Y(mm) Z(mm) KinE(MeV) dE(MeV) StepLeng TrackLeng NextVolume ProcName
G4WT0 > 0 -226 0.0513 0.00364 0.106 0 0 0 phantomPhys initStep
G4WT0 > 1 -226 0.0546 0.0467 0.0454 0.0603 0.13 0.13 DetectorPhys DetectorROGeometry
G4WT0 > 2 -226 0.0619 0.0627 0 0.0454 0.0335 0.164 DetectorPhys eIoni
G4WT0 > Track (trackID 12, parentID 1) is processed with stopping code 3
G4WT0 > ### pop requested out of 0 stacked tracks.
G4WT0 > ### 0 waiting tracks are re-classified to
G4WT0 > 0 urgent tracks and 0 waiting tracks.
G4WT0 > NULL returned from G4StackManager.
G4WT0 > Terminate current event processing.
n
If my understanding of this kill command is wrong, can you suggest me how do I implement it such that I don’t see e+ annihilating at all. Thank you for the help.
Best,
Ananta
