– The C compiler identification is GNU 7.5.0
– The CXX compiler identification is GNU 7.5.0
– Check for working C compiler: /usr/bin/cc
– Check for working C compiler: /usr/bin/cc – works
– Check for working CXX compiler: /usr/bin/c++
– Check for working CXX compiler: /usr/bin/c++ – works
– Found XercesC: /usr/lib/x86_64-linux-gnu/libxerces-c.so (found suitable version “3.2.0”, minimum required is “3.2.0”)
– Looking for XOpenDisplay in /usr/lib/x86_64-linux-gnu/libX11.so;/usr/lib/x86_64-linux-gnu/libXext.so
– Looking for XOpenDisplay in /usr/lib/x86_64-linux-gnu/libX11.so;/usr/lib/x86_64-linux-gnu/libXext.so - found
– Looking for gethostbyname
– Looking for gethostbyname - found
– Looking for connect
– Looking for connect - found
– Looking for remove
– Looking for remove - found
– Looking for shmat
– Looking for shmat - found
– Looking for IceConnectionNumber in ICE
– Looking for IceConnectionNumber in ICE - found
– Found X11: /usr/lib/x86_64-linux-gnu/libX11.so
– Looking for Q_WS_X11
– Looking for Q_WS_X11 - found
– Looking for Q_WS_WIN
– Looking for Q_WS_WIN - not found
– Looking for Q_WS_QWS
– Looking for Q_WS_QWS - not found
– Looking for Q_WS_MAC
– Looking for Q_WS_MAC - not found
– Found Qt4: /usr/bin/qmake-qt4 (found version “4.8.7”)
– Found OpenGL: /usr/lib/x86_64-linux-gnu/libOpenGL.so
– Configuring done
– Generating done
– Build files have been written to: /home/ai/Desktop/P/pyramid/I
What exactly is your problem? Build files have been written, so it look to have completed successfully.
my problem, when i start “make” the files they give me that
"(base) ai@AI:~/Desktop/P/pyramid/I$ make
Scanning dependencies of target task
[ 11%] Building CXX object CMakeFiles/task.dir/main.cc.o
/home/ai/Desktop/P/pyramid/main.cc: In function ‘int main(int, char**)’:
/home/ai/Desktop/P/pyramid/main.cc:31:10: warning: variable ‘interactive’ set but not used [-Wunused-but-set-variable]
bool interactive = false;
[ 22%] Building CXX object CMakeFiles/task.dir/src/ActionInitialization.cc.o
[ 33%] Building CXX object CMakeFiles/task.dir/src/DetectorConstruction.cc.o
[ 44%] Building CXX object CMakeFiles/task.dir/src/EventAction.cc.o
[ 55%] Building CXX object CMakeFiles/task.dir/src/PhysicsList.cc.o
[ 66%] Building CXX object CMakeFiles/task.dir/src/PrimaryGeneratorAction.cc.o
[ 77%] Building CXX object CMakeFiles/task.dir/src/RunAction.cc.o
[ 88%] Building CXX object CMakeFiles/task.dir/src/StackingAction.cc.o
[100%] Linking CXX executable task
[100%] Built target task
(base) ai@AI:~/Desktop/P/pyramid/I$ ./task
Geant4 version Name: geant4-10-06-patch-01 (14-February-2020)
: IEEE-TNS 53 (2006), 270-278
: NIM A 835 (2016), 186-225
WWW : http://geant4.org/
… open Root analysis file : task6.root - done
G4 kernel has come to Quit state.
… write Root file : task6.root - done
================== Deleting memory pools ===================
Number of memory pools allocated: 2; of which, static: 0
Dynamic pools deleted: 2 / Total memory freed: 0.0038 MB
RunManagerKernel is deleted. Good bye
the simulation is open and close at the same time and it never visualize, I try to install qt and opengl and many libraries at Geant 4 again but it never works.
i hope you have the answer of this problem
So that’s your problem! Looks like it’s running in “batch mode”. To run in interactive mode you have to make sure your main program starts an interactive session. Typically:
ui->SessionStart();
you can see this is the main file from inside the ui->SessionStart(); is exist
"#include
#include <G4RunManager.hh>
#ifdef G4VIS_USE
#include <G4VisExecutive.hh>
#endif
#ifdef G4UI_USE
#include <G4UIExecutive.hh>
#endif
#include <G4String.hh>
#include <G4UImanager.hh>
#include <G4ScoringManager.hh>
#include “ActionInitialization.hh”
#include “DetectorConstruction.hh”
#include “PhysicsList.hh”
using namespace std;
/* Main function that enables to:
- run any number of macros (put them as command-line arguments)
- start interactive UI mode (no arguments or “-i”)
int main(int argc, char* argv)
vector macros;
// Parse command line arguments
if (argc == 1)
interactive = true;
else
for (int i = 1; i < argc; i++)
G4String arg = argv[i];
if (arg == “-i” || arg == “–interactive”)
interactive = true;
continue;
else
macros.push_back(arg);
}//Use sequential mode only
G4RunManager* runManager = new G4RunManager();
runManager->SetVerboseLevel(1);#ifdef G4VIS_USE
G4VisManager* visManager = new G4VisExecutive();
visManager->SetVerboseLevel(0); // Default, you can always override this using macro commands
visManager->Initialize();
#endifrunManager->SetUserInitialization(new PhysicsList());
runManager->SetUserInitialization(new DetectorConstruction());
runManager->SetUserInitialization(new ActionInitialization());#ifdef G4UI_USE
G4UIExecutive* ui;
if (interactive)
ui = new G4UIExecutive(argc, argv);
#endifG4UImanager* UImanager = G4UImanager::GetUIpointer();
for (auto macro : macros)
UImanager->ApplyCommand(command + macro);
}#ifdef G4UI_USE
if (interactive)
UImanager->ApplyCommand("/control/execute macros/vis.mac");
UImanager->ApplyCommand("/control/execute macros/gps.mac");
ui->SessionStart();
delete ui;
#endifdelete runManager;
return 0;
" - start interactive UI mode (no arguments or “-i”)
It exists. But is it executed?
see that …
(base) ai@AI:~/Geant4/g4-install/share/Geant4-10.6.1/examples/pyramid/X$ source /home/ai/Geant4/g4-install/bin/geant4.sh
(base) ai@AI:~/Geant4/g4-install/share/Geant4-10.6.1/examples/pyramid/X$ cmake -DGeant4_DIR= /home/ai/Geant4/g4-install/lib/Geant4-10.6.1/ …/
– Looking for shmat
– Configuring done
– Generating done
– Build files have been written to: /home/ai/Geant4/g4-install/share/Geant4-10.6.1/examples/pyramid/X
(base) ai@AI:~/Geant4/g4-install/share/Geant4-10.6.1/examples/pyramid/X$ make
/home/ai/Geant4/g4-install/share/Geant4-10.6.1/examples/pyramid/main.cc: In function ‘int main(int, char**)’:
/home/ai/Geant4/g4-install/share/Geant4-10.6.1/examples/pyramid/main.cc:31:10: warning: variable ‘interactive’ set but not used [-Wunused-but-set-variable]
(base) ai@AI:~/Geant4/g4-install/share/Geant4-10.6.1/examples/pyramid/X$ ./task
I can not figure where is the problem, if it missing library
or the linux or what is happening
and the compiler run the examples of the Geant 4 well but not that code i do not know why !!!
okay for your concern – i try to solve it with a friend – and i comment #ifdef G4VIS_USE and #ifdef G4UI_USE
and it worked as well but that is not the solution
so I can ask know what is the library that control all of that ?
Ah, yes. Sorry, I did not notice #ifdef G4VIS_USE
in your code. They are no longer set in Geant4 10.6. From the Release Notes for 10.6:
- The preprocessor macros G4UI_USE and G4VIS_USE are removed.
