I verifiied that this problem can still be observed in the current version (10.07.p01). What I find is that in my application (18 GeV electrons on a copper beam
dump, modeling a SLAC experiment carried out in 1974), starting with the 10.06.p02 version,
electrons below ~2 MeV would lose energy exclusively via the “msc” process -
and this made the tracking much slower,
because it created much more stepping activity respect to the 10.06.p01-version,
in which low-energy electrons lose energy much quicker through the
“eIon”-process. This is connected to the “Safety” parameter in the stepping
procedure, which is apparently always set to “5.0000000000000003e-10” in
p02 (and following versions), forcing the “msc” to win over the “eIon” process (in p01 versions, this
parameter takes values which seem to be somehow proportional to the particle
energy, and change for the different processes which are probed, but I do
not know what this parameter represents).
The “Safety”-parameter derives from the “proposedSafety”-value, which
seems to be always “0.” in versions >= 10.06.p02. I have not found out yet why this is
the case.
The problem is then that in G4SteppingManager.cc:198
// endpointSafety= std::max( proposedSafety - GeomStepLength, 0.);
kCarTolerance);
with usually “GeomStepLength” > 0., the first expression becomes negative
and “endpointsafety” takes the value of “kCarTolerance” (which is set to
0.5*G4GeometryTolerance::GetInstance()->GetSurfaceTolerance(); in
G4SteppingManager.cc and evaluates to 5.0000000000000003e-10)
Apparently, this does not change the stepping results for the first 100
steps or so (the energy of the primary electron going down from 18 GeV to 2
MeV), but then in line 519 of
processes/electromagnetic/standard/src/G4GoudsmitSaundersonMscModel.cc
there is a condition
if (gIsOptimizationOn && (distance<presafety))
which evaluates to ‘false’ for p02 since “presafety” is always smaller
than “distance”, while it is ‘true’ for p01. This results in a
recalculation of many quantities, to the effect that from now on for every
step, ‘msc’ process seems to win with the shortest steplength.
Discussing with Alberto Ribon and other experts on GEANT4, it was found that
this behavior is triggered by the G4GenericBiasingPhysics.cc-file -
replacing G4GenericBiasingPhysics.cc in geant4.10.07p01 with the one from
geant4.10.06p01 speeds up my calculations considerably, and recovers the
pre-p02 conditions.
I am aware that this file has been updated to fix a bug related to
parallel geometries and generic biasing, and I should preferably use the
most recent one. But since I am apparently one of the few people using both
primitive scorers and generic biasing in my application, this may explain
why I am apparently the only person affected so far by an increase in running
time (we talk about a factor 5-6!).
My question now is whether the fact that the “Safety”-parameter always takes
the value of “5.0000000000000003e-10” is intended behavior, or if this is an
unhappy coincidence which should be rectified?
