Hi everyone!
I’m using Geant4 as a raytracer for xrays in the 1-30keV energy range, on low Z (water, CH) targets. I’ve had trouble with the absorption not matching what I would expect from experimental data (obtained from cxro: CXRO X-Ray Interactions With Matter). The geant4 absorption (beta in the complex refractive index) for CH at 15keV is 0.51x what I would expect from cxro. The 0.51 changes for different energies and different materials (for water it’s 1.08x at 15keV).
Does anyone have ideas as to why this might be?
Further details:
The testing setup is a series of slices, of equal dimensions, each with increasing density(so different absorption) being backlit by a flat (columnated) source (using /gps), with mono energetic photons initially at 15keV (later tests tried different energies). A schematic is shown:
As I’m a new user, I can’t show more images, the images are given in the github which also contains the geant4 code that generated the images:
the analysis was written in python and is part of another code, I’m working on extracting it to its own repository
The image on the detector (obtained using /scoring) is CH_15keV_output.png, a lineout is shown in blue. The expected absorption, calculated using the imaginary part of the refractive index(beta
, different for each slice), is shown in red.
The expected transmission was calculated with this formula:
wavelength_m = 1239.842 * np.power(10.0, -9) / energy_eV
mu = 4 * np.pi * thickness_m * beta / wavelength_m
transmission_fraction = np.exp(-mu)
For each of these slices, the beta
suggested by geant4’s actual transmission can be calculated:
mu = -np.log(transmission)
wavelength_m = get_wavelength(energy_eV)
beta = mu*float(wavelength_m)/(4 * np.pi * float(thickness_m))
This can then be plotted against the beta
from cxro to show there is a linear relationship, with a coefficient which is energy and material dependent. In the github, there are graphs for CH_15keV, CH_20keV, water_15keV, each of which have different coefficients (0.51, 0.62 and 1.08 respectively). For CH, the coefficients were linear with energy (so 25keV is 0.72).
Thanks for any help!
