Hello, I use Geant4 on cvmfs installed on a machine on a first laboratory and it works.
This is the compiling of the simulation
-- The C compiler identification is GNU 8.3.0
-- The CXX compiler identification is GNU 8.3.0
-- Check for working C compiler: /cvmfs/sft.cern.ch/lcg/releases/gcc/8.3.0-cebb0/x86_64-centos7/bin/gcc
-- Check for working C compiler: /cvmfs/sft.cern.ch/lcg/releases/gcc/8.3.0-cebb0/x86_64-centos7/bin/gcc -- works
-- Check for working CXX compiler: /cvmfs/sft.cern.ch/lcg/releases/gcc/8.3.0-cebb0/x86_64-centos7/bin/g++
-- Check for working CXX compiler: /cvmfs/sft.cern.ch/lcg/releases/gcc/8.3.0-cebb0/x86_64-centos7/bin/g++ -- works
-- Found EXPAT: /cvmfs/sft.cern.ch/lcg/views/LCG_geant4ext20210118/x86_64-centos7-gcc8-opt/lib64/libexpat.so (found suitable version "2.2.6", minimum required is "2.2.6")
-- Looking for pthread.h
-- Looking for pthread.h - found
-- Looking for pthread_create
-- Looking for pthread_create - not found
-- Check if compiler accepts -pthread
-- Check if compiler accepts -pthread - yes
-- Found Threads: TRUE
-- Found XercesC: /cvmfs/sft.cern.ch/lcg/views/LCG_geant4ext20210118/x86_64-centos7-gcc8-opt/lib/libxerces-c.so (found suitable version "3.2.3", minimum required is "3.2.3")
-- Found X11: /usr/include
-- Looking for XOpenDisplay in /usr/lib64/libX11.so;/usr/lib64/libXext.so
-- Looking for XOpenDisplay in /usr/lib64/libX11.so;/usr/lib64/libXext.so - found
-- Looking for gethostbyname
-- Looking for gethostbyname - found
-- Looking for connect
-- Looking for connect - found
-- Looking for remove
-- Looking for remove - found
-- Looking for shmat
-- Looking for shmat - found
-- Looking for IceConnectionNumber in ICE
-- Looking for IceConnectionNumber in ICE - found
-- Found OpenGL: /usr/lib64/libOpenGL.so
-- Found Motif: /usr/lib64/libXm.so
-- Configuring done
-- Generating done
-- Build files have been written to:SimulazionLNGS/kinematics/B1/B1-build
On the contrary, Geant4 on cvmfs using a machine on a second laboratory doesn’t work…the compiling is different and I get error
-- Found XercesC: /cvmfs/sft.cern.ch/lcg/views/LCG_99/x86_64-centos7-gcc8-opt/lib/libxerces-c.so (found suitable version "3.2.3", minimum required is "3.2.3")
-- Detected Compiler: GCC 8.3.0
-- Performing Test check_cxx_compiler_flag__Wabi
-- Performing Test check_cxx_compiler_flag__Wabi - Success
-- Performing Test check_cxx_compiler_flag__fabi_version_0
-- Performing Test check_cxx_compiler_flag__fabi_version_0 - Success
-- Performing Test check_cxx_compiler_flag__fabi_compat_version_0
-- Performing Test check_cxx_compiler_flag__fabi_compat_version_0 - Success
-- Performing Test check_cxx_compiler_flag__ffp_contract_fast
-- Performing Test check_cxx_compiler_flag__ffp_contract_fast - Success
-- target changed from "" to "auto"
-- Detected CPU: k8
-- Performing Test check_cxx_compiler_flag__march_k8
-- Performing Test check_cxx_compiler_flag__march_k8 - Success
-- Performing Test check_cxx_compiler_flag__msse2
-- Performing Test check_cxx_compiler_flag__msse2 - Success
-- Performing Test check_cxx_compiler_flag__mno_sse3
-- Performing Test check_cxx_compiler_flag__mno_sse3 - Success
-- Performing Test check_cxx_compiler_flag__mno_ssse3
-- Performing Test check_cxx_compiler_flag__mno_ssse3 - Success
-- Performing Test check_cxx_compiler_flag__mno_sse4_1
-- Performing Test check_cxx_compiler_flag__mno_sse4_1 - Success
-- Performing Test check_cxx_compiler_flag__mno_sse4_2
-- Performing Test check_cxx_compiler_flag__mno_sse4_2 - Success
-- Performing Test check_cxx_compiler_flag__mno_sse4a
-- Performing Test check_cxx_compiler_flag__mno_sse4a - Success
-- Performing Test check_cxx_compiler_flag__mno_avx
-- Performing Test check_cxx_compiler_flag__mno_avx - Success
-- Performing Test check_cxx_compiler_flag__mno_fma
-- Performing Test check_cxx_compiler_flag__mno_fma - Success
-- Performing Test check_cxx_compiler_flag__mno_bmi2
-- Performing Test check_cxx_compiler_flag__mno_bmi2 - Success
-- Performing Test check_cxx_compiler_flag__mno_avx2
-- Performing Test check_cxx_compiler_flag__mno_avx2 - Success
-- Performing Test check_cxx_compiler_flag__mno_xop
-- Performing Test check_cxx_compiler_flag__mno_xop - Success
-- Performing Test check_cxx_compiler_flag__mno_fma4
-- Performing Test check_cxx_compiler_flag__mno_fma4 - Success
-- Performing Test check_cxx_compiler_flag__mno_avx512f
-- Performing Test check_cxx_compiler_flag__mno_avx512f - Success
-- Performing Test check_cxx_compiler_flag__mno_avx512vl
-- Performing Test check_cxx_compiler_flag__mno_avx512vl - Success
-- Performing Test check_cxx_compiler_flag__mno_avx512pf
-- Performing Test check_cxx_compiler_flag__mno_avx512pf - Success
-- Performing Test check_cxx_compiler_flag__mno_avx512er
-- Performing Test check_cxx_compiler_flag__mno_avx512er - Success
-- Performing Test check_cxx_compiler_flag__mno_avx512cd
-- Performing Test check_cxx_compiler_flag__mno_avx512cd - Success
-- Performing Test check_cxx_compiler_flag__mno_avx512dq
-- Performing Test check_cxx_compiler_flag__mno_avx512dq - Success
-- Performing Test check_cxx_compiler_flag__mno_avx512bw
-- Performing Test check_cxx_compiler_flag__mno_avx512bw - Success
-- Performing Test check_cxx_compiler_flag__mno_avx512ifma
-- Performing Test check_cxx_compiler_flag__mno_avx512ifma - Success
-- Performing Test check_cxx_compiler_flag__mno_avx512vbmi
-- Performing Test check_cxx_compiler_flag__mno_avx512vbmi - Success
CMake Error at /cvmfs/sft.cern.ch/lcg/views/LCG_99/x86_64-centos7-gcc8-opt/lib/cmake/Qt5Gui/Qt5GuiConfig.cmake:15 (message):
The imported target "Qt5::Gui" references the file
"/lib64/libEGL.so"
but this file does not exist. Possible reasons include:
* The file was deleted, renamed, or moved to another location.
* An install or uninstall procedure did not complete successfully.
* The installation package was faulty and contained
"/cvmfs/sft.cern.ch/lcg/views/LCG_99/x86_64-centos7-gcc8-opt/lib/cmake/Qt5Gui/Qt5GuiConfigExtras.cmake"
but not all the files it references.
/cvmfs/sft.cern.ch/lcg/views/LCG_99/x86_64-centos7-gcc8-opt/lib/cmake/Qt5Gui/Qt5GuiConfigExtras.cmake:45 (_qt5_Gui_check_file_exists)
/cvmfs/sft.cern.ch/lcg/views/LCG_99/x86_64-centos7-gcc8-opt/lib/cmake/Qt5Gui/Qt5GuiConfigExtras.cmake:67 (_qt5gui_find_extra_libs)
/cvmfs/sft.cern.ch/lcg/views/LCG_99/x86_64-centos7-gcc8-opt/lib/cmake/Qt5Gui/Qt5GuiConfig.cmake:174 (include)
/cvmfs/sft.cern.ch/lcg/contrib/CMake/3.14.2/Linux-x86_64/share/cmake-3.14/Modules/CMakeFindDependencyMacro.cmake:48 (find_package)
/cvmfs/sft.cern.ch/lcg/views/LCG_99/x86_64-centos7-gcc8-opt/lib64/Geant4-10.7.0/Geant4Config.cmake:452 (find_dependency)
CMakeLists.txt:16 (find_package)
Why the compiling is different? And why do I get error on the second machine?
@bmorgan maybe do you know it?
