Hadrontherapy example (CATANA): nozzle brass tubes, modulator wheel position and the clinical SOBP modulator file
I am using the advanced example Hadrontherapy (Geant4 11.3) to model the CATANA 62 MeV passive proton beamline, for the U87 cell irradiations of Chaudhary et al. (2014), done around 2012-2014. I have three short questions about the geometry of the example:
  1. In PassiveProtonBeamLine.cc the brass tubes of the nozzle have a 36 mm inner diameter and a total length of 360 mm. Givehchi et al. (Phys Med 2011;27:233) describe a 370 mm long brass collimator with a 25 mm internal diameter. Which one corresponds to the beamline used for cell irradiations at that time?
  2. HadrontherapyModulator.cc places the centre of the modulator wheel at x = -2160.5 mm, while Jia et al. (NIM A 806 (2016) 101) write that the wheel is placed 2050 mm upstream of the isocenter. The History file notes “Range shifter and modulator positions corrected”. Which position corresponds to the real line?
  3. Which of the modulator files distributed with the example (Modulator009_02, Modulator010, Modulator011, ModulatorAM16FR) corresponds to the clinical wheel that gives the 11 mm SOBP? If the clinical wheel is not among them, is its step file available?
Any hint would be very welcome. Thank you.
Ava Rasta
MSc student, Amirkabir University of Technology (Tehran Polytechnic)
