Is the directory holding the installed G4OpenGL.dll
library listed in the PATH
environment variable in the session you are running from?
thank you for your reply sir, sorry i am just a biginner and i followed youtube video instructions to do the compilation and installation. i don`t know how to confirm if the directory is holding the installed G4OpenGL.dll library. i need more help thank you for your time.
The current canonical documentation on building, and installing and post-install configuration is in or Install Guide. In particular, for this issue, see the section on Installing on Windows (the .dll
s will be be somewhere under the directory you used for the CMAKE_INSTALL_PREFIX
variable), and the Post Install Setup guide.
The Application Developer Guide should also provide some additional details on the example build/use process.
This topic was automatically closed 90 days after the last reply. New replies are no longer allowed.
