I am new to geant4 and I am using geant4 to conduct a simulation which requires a geometry with hexagonal lattice placement. The geometry consists of a hexagonal placement of smaller sub-geometry (small spheres). I used for loops to place spheres into a larger lattice sphere. However, the program encounters segmentation fault when the amount of small sphere is large. I was wondering if there is any way to solve this or another way to construct such geometry.
Thanks in advance.
the code is pasted here:
latticeS = new G4MultiUnion(“MOFLatticeSolid”);
G4double limit = round((flattice_radius-frmax_mof)/fdistance);
for (G4double i=-limit; i<=limit; i++) //2*limit is the total number along the axis
for (G4double j=-limit; j<=limit; j++)
for (G4double k=-limit; k<=limit; k++)
G4double x1=i*fdistance;
G4double x2=(0.5+i)*fdistance;
G4double y1=j*fdistance;
G4double y2=(0.5+j)*fdistance;
G4double y3=(0.25+j)*fdistance;
G4double y4=(j-0.25)*fdistance;
G4double z1=2*k*sin(60*deg)*fdistance;
G4double z2=(2*k+1)*sin(60*deg)*fdistance;
G4ThreeVector position1 = G4ThreeVector(x1, y1, z1);
G4ThreeVector position2 = G4ThreeVector(x2, y2, z1);
G4ThreeVector position3 = G4ThreeVector(x1, y3, z2);
G4ThreeVector position4 = G4ThreeVector(x2, y4, z2);
G4RotationMatrix rotm = G4RotationMatrix(); //no rotation
G4Transform3D transform1 = G4Transform3D(rotm,position1);
G4Transform3D transform2 = G4Transform3D(rotm,position2);
G4Transform3D transform3 = G4Transform3D(rotm,position3);
G4Transform3D transform4 = G4Transform3D(rotm,position4);
if (containerS->Inside(position1)==kInside){
latticeS->AddNode(*mofS,transform1);} //to see whether the point is in a container sphere
if (containerS->Inside(position2)==kInside){
latticeS->AddNode(*mofS,transform2);}
if (containerS->Inside(position3)==kInside){
latticeS->AddNode(*mofS,transform3);}
if (containerS->Inside(position4)==kInside){
latticeS->AddNode(*mofS,transform4);}
//close the solid structure
latticeS->Voxelize();
