I don’t want set in terminal any time when run some file value of source to:
source ~/Documents/GEANT4/geant4-v11.0.2-install/bin/geant4.sh
Is there any way to set it once somewhere for all time calculations ?
Assuming this is a macOS system and the Zsh shell is being used, that line can be added to ~/.zshrc
or ~/.zprofile
(~/.bashrc
or ~/.profile
for Bash shell). It’ll then be sourced on each new login or session.
Can I add that line rverywhere in .bashrc file or I should do it somwhere concretely ?
Sorry, I’m not sure what you mean - it only needs adding once in one file, so if you are using Bash, then simply paste it once in .bashrc
