How to describe the abundance in Hadr03
Hello geant4 users, i`m using Hadr03 ion.mac to study the cross section for several radioisotopes but up to now i have a problem, how can i describe the abundance of the radioisotpe in detector construction? or is there any method to describe it in the input file?
_Geant4 Version:_10.2
_Operating System: virtual box machine
_CMake Version:_3.16.3
see Geant4 documentation: Material — Book For Application Developers 11.2 documentation
or example TestEm3: DetectorConstruction.cc, around lines 123-135
please, notice that, by default, G4Element build isotopes with natural abundance
thank you maire, but i sitll hace a problem i tried what is in the ex TestEm3 the terminal show me some errors, i tried to put the abundance of 82Kr in the detector construction but it doesn’t change in the output file, it is still 100%
as you see in the figure i wrote 0.56 but in the output file it still 100
Internally, Geant4 system double check the ratio of each component.
You build your element with one isotope only —> 100 % !
In TestEm3, read again the definition of " enriched Uranium "
