I made a simulation of Co-60, but I do not know what happen when I try to save the data. What I need is this spectrum
I have these results, but I can not made the gamma spectrum of Co-60:
I made the saving in RunAction:
void runaction::BeginOfRunAction(const G4Run*){
// initializate the run manager to store the hits
G4AnalysisManager*man = G4AnalysisManager::Instance();
//man->SetHistoDictoryName(“histograms”);
// create the root file
man->OpenFile(“output.root”);
man->CreateH1("Edep","Counts",200,0,2.5*MeV);
man->CreateNtuple("Hits","Edep in NaI");
man->CreateNtupleFColumn("Edep");
man->FinishNtuple();
and in my sensitive detector class:
sensitivedetector::~sensitivedetector(){}
G4bool sensitivedetector::ProcessHits(G4Step* aStep,G4TouchableHistory* ROhist){
G4double edep= aStep->GetTotalEnergyDeposit();
// show us the edep
G4cout<< "Energy deposited is"<<edep<<G4endl;
man->FillH1(0,edep);
man->FillNtupleFColumn(0,edep);
man->AddNtupleRow();
Hi, you are saving the edep of each hit in your detector. I think you should integrate the edep of the hits within one event. Look at the Sensitive Detector Class of the radioprotection advanced example. There, the edep of the hits is integrated at the end of each event.
It looks like you are recording each individual energy deposit from each step in the event. If your simulation is simple, where the only active volume is the detector, then what you should do is sum (integrate) all of the Edep values in each event.
The total energy will have a peak at the incident gamma energy, and will have a tail corresponding to energy which was “lost” (secondaries which escape out of the detector volume).
In your N-tuple, include the event number. Then, in your analysis code afterward, as you loop over rows, sum up all the Edep values for the same event number.
