I write codes as below.
But the terminal do not execute it.
file.open("/home/priyanshu/Documents/workingdir./Example/advanced/radioprotection/mytext.txt", std::ios::app);
file<<“energy deposited:\t” << edepStep/MeV<< G4endl;
like this, i think you can get. please try this and give the name of the directory where you want to save that file.
Goodmorning, I was interest in something similar. I can i save all the run output into a txt file? Thanks a lot
I am not sure what the problem is. C++ provides ways of writing data to file. Simply get the information you want (in your stepping action or similar) and use C++ to write it to file.
So, is your problem: “How to get the data”; or “How to write C++”?
In addition, in multithreading mode, you need to protect the output statements with mutex locks.
redirect all output (G4cerr, G4cout, everything the app prints out) to textfile in the command line:
./yourApp > logfile.txt
or separate err/out:
./yourApp 2>err.txt 1>out.txt
for windows, you would have to google yourself
I actually need it for Windows and couldn’t find it anywhere on google. If you can help me would be really appreciated.
I found it, thanks anyway!
