I understand how to implement multiple sources using GPS with each source’s info defined in the macro.
How can I implement this using particle gun
in the macro? For instance, in the attached adaptation from rdecay
example, I generate 500 events of 100 keV electrons. Can I also define protons of 120 keV energy, such that 250 events are simulated for the 100-keV electrons and the rest 250 for the protons of 120 keV energy?
I tried defining /run/beamOn 250
twice but that overwrites the test.root
created from the first instance. If I rename the file after first /run/beamOn 250
, two ROOT files are generated and the event number of the second ROOT file starts from zero; which is not desired.
Any suggestions please?
