I know this is probably a dumb question, but i am having problem because when i run any example in geant, the option /gps does not appear in the interactive mode. I suspect that i should include it somewhere, but i am not sure what should i do.
In another words, how do i “include” the option /gps in geant4? is there a tutorial showing how to integrate it in any program?
The “/gps” commands are defined by the G4GeneralParticleSource. If your primary generator action is using G4ParticleGun, then you’ll get the much more limited “/gun” commands.
Several of the extended and advanced examples use GPS as their source. You may want to use the commands
