Hi there, I am looking to introduce Gadolinium Sulfate (Gd2O12S3) in a certain volume. I looked in the book for application developers but could not find it. So my question is: can I introduce, in the volume, the right proportion of Gd, O and S separately to simulate the Gadolinium sulfate?
examples/basic/B3 : DetectorConstruction.cc
Hi Michael, thank you very much for the reply.
I completely forgot to look up the examples, sorry about that.
Hi @maire. So I have managed to define the new compound correctly but now I get this error message when trying to run the application.
physicsList->setCut() start.
*** G4Exception : GeomMgt0002
issued by : G4Region::ScanVolumeTree()
Logical volume
does not have a valid material pointer.
A logical volume belonging to the (tracking) world volume must have a valid material.Check your geometry construction.*** Fatal Exception *** core dump ***
**** Step information is not available at this moment-------- EEEE -------- G4Exception-END --------- EEEE -------
I don’t know how to define the material as a valid material or even if it is possible to do so.
Thanks in advance.
The answer is also in B3 : DetectorConstruction.cc
Or any other example …
Thank you for your time Michel.
Dear @Diego, did you figure out introducing Gadolinium Sulfate (Gd2O12S3) ? I also want to describe this material in my simulation. I want to use 0.2% Gd-sulphate by weight into the water. but don’t know how to set concentration of all elements. Could you help me with it?
Define gadolinium sulfate first, as a pure material, using the stoichiometry. Then define your solution as a mixture of the defined materials water (already defined, see G4_WATER) at 0.998 and your GdSO at 0.002. Geant4 will take care of the overall elemental distributions.
See example TestEm1/src/DetectorConstruction.cc, lines 161-165
