Is there a G4 Class to change the concentration of an element in a material as a function of distance when constructing a detector? i.e. a depth profile.
Example being a block of metal where hydrogen has diffused through from 1 side.
You want to have a look at parameterised volumes:
You will need to override the ComputeMaterial
method such that the concentration depends on the copy id (an integer) of the daughter material.
It is not the most straight-forward of tasks, but you have a few examples using this approach. Good luck!
