I think it is also complaining about the Qt.
I remembered there are some functions in my Geant4 coding which cannot be used in the newest version of Geant4, so I am still using the Geant 4 version of 10.7.1…
You may need to delete and recreate the Geant4 build directory as CMake caches found packages. I’d guess as you noted it’s found the Conda Qt5, so it may have cached that and then ignored your update zsh settings.
Regarding screenshots, we much prefer if you are able to copy and paste the text directly inside fenced code blocks, e.g. typing
```console
$ echo "hello"
displays as:
$ echo "hello"
that makes it much easier to check and search the text.
