I do not understand why in some cases the ProcessHits method of my SensitiveDetector class was not called when the particle hit the cell volume (defined as Sensitive Detector). I investigate using /tracking/verbose.
For example, the /tracking/verbose information shows that for the main particle, in the steps 17 and 26 there was energy deposit but I did not get my debug message « THGCalSD::ProcessHits ». In the case of the secondary particle, in the step 10, I got it.
I did not use any cut in the simulation.
Any ideas why this happens or how to investigate further?
Thank you!
G4WT0 > -> Event: 0
G4WT0 >
G4WT0 > *********************************************************************************************************
G4WT0 > * G4Track Information: Particle = e-, Track ID = 1, Parent ID = 0
G4WT0 >
G4WT0 > Step# X(mm) Y(mm) Z(mm) KinE(MeV) dE(MeV) StepLeng TrackLeng NextVolume ProcName
G4WT0 > 0 0 0 -120 5e+04 0 0 0 World initStep
G4WT0 > 1 0 0 -6.42 5e+04 0.0202 114 114 Absorber Transportation
G4WT0 > 2 7.18e-05 -3.71e-05 -5.67 5e+04 0.79 0.75 114 Absorber eBrem
G4WT0 > 3 8.24e-05 -4.86e-05 -5.49 4.93e+04 0.23 0.184 115 Absorber eBrem
G4WT0 > 4 0.000103 -0.000112 -5.15 4.36e+04 0.377 0.333 115 Absorber eBrem
G4WT0 > 14 0.00121 -0.00284 -1.96 8.36e+03 0.217 0.212 118 Absorber eBrem
G4WT0 > 15 0.00211 -0.00429 -0.82 8.36e+03 1.58 1.14 119 World Transportation
G4WT0 > 16 0.00216 -0.00463 -0.32 8.36e+03 0.000151 0.5 120 Cell Transportation
G4WT0 > 17 0.00219 -0.00485 0 8.36e+03 0.095 0.32 120 World Transportation
G4WT0 > 18 0.00241 -0.00607 1.58 8.36e+03 0.000229 1.58 122 Absorber Transportation
G4WT0 > 19 0.00276 -0.00654 2.41 8.36e+03 0.937 0.829 122 Absorber eBrem
G4WT0 > 24 0.00384 -0.0117 7.18 3.58e+03 0.0537 0.0305 127 World Transportation
G4WT0 > 25 0.0039 -0.0124 7.68 3.58e+03 0.000153 0.5 128 Cell Transportation
G4WT0 > 26 0.00393 -0.0129 8 3.58e+03 0.112 0.32 128 World Transportation
G4WT0 > 27 0.00714 -0.0365 27.5 3.58e+03 0.00412 19.5 148 World eIoni
G4WT0 > 28 0.0257 -0.149 120 3.58e+03 0.0195 92.5 240 OutOfWorld Transportation
G4WT0 > * G4Track Information: Particle = e-, Track ID = 135, Parent ID = 116
G4WT0 >
G4WT0 > 0 -0.00666 0.03 2.23 72.3 0 0 0 Absorber initStep
G4WT0 > 1 -0.000328 0.0208 2.65 70.8 0.512 0.412 0.412 Absorber eBrem
G4WT0 > 2 0.103 -0.127 4.65 66.5 2.62 2.03 2.44 Absorber eIoni
G4WT0 > 3 0.805 -0.945 5.52 64.1 1.71 1.38 3.83 Absorber eBrem
G4WT0 > 4 1.22 -1.92 6.24 54.9 1.77 1.28 5.11 Absorber eBrem
G4WT0 > 5 1.46 -2.48 6.8 53.4 1.18 0.826 5.94 Absorber eBrem
G4WT0 > 6 1.49 -2.59 6.88 53 0.171 0.142 6.08 Absorber eBrem
G4WT0 > 7 1.55 -2.75 7.02 39.4 0.241 0.226 6.31 Absorber eBrem
G4WT0 > 8 1.61 -2.93 7.18 39.1 0.263 0.245 6.55 World Transportation
G4WT0 > 9 1.74 -3.49 7.68 39.1 5.92e-05 0.762 7.31 Cell Transportation
G4WT0 > 10 1.83 -3.85 8 39 0.176 0.488 7.8 World Transportation
G4WT0 > THGCalSD::ProcessHits
G4WT0 > 1 cellID: 121 volPos: (2,-3.464101615137754,8) edep: 0.1758702335547624
G4WT0 > 11 11.7 -38.5 39.2 38.9 0.00677 47.6 55.4 World eIoni
G4WT0 > 12 16.3 -55 54.2 38.9 0.00298 22.8 78.3 World eIoni
G4WT0 > 13 34.6 -120 113 38.9 0.0185 89.6 168 OutOfWorld Transportation
