Modify the momentum and position of particles when they pass through specific volume
I want to change the momentum and position of particles when they pass through specific volume. I did using the following code:
if(track->GetVolume()->GetName() == "scintillator"){
    // Modify the position
    G4ThreeVector newPosition(1*CLHEP::cm, 1*CLHEP::cm, 2*CLHEP::cm);
    track->SetPosition(newPosition);
    // Modify the momentum direction
    G4ThreeVector newMomentumDirection(1, 0, 0);  // Example: Set to x direction
    track->SetMomentumDirection(newMomentumDirection);
    std::cout << "Changed Track" << std::endl;
the program running properly but it is giving following warning:
*** G4Exception : GeomNav1002
Accuracy error or slightly inaccurate position shift.
The Step’s starting point has moved 1920.6 mm
since the last call to a Locate method.
This has resulted in moving 1920.6 mm from the last point at which the safety was calculated
which is more than the computed safety= 0.01 mm at that point.
This difference is 1920.6 mm.
The tolerated accuracy is 1e-06 mm.
This problem can be due to either
- a process that has proposed a displacement larger than the current safety , or
- inaccuracy in the computation of the safety We suggest that you
  • find i) what particle is being tracked, and ii) through what part of your geometry
    for example by re-running this event with
    /tracking/verbose 1
    - check which processes you declare for this particle (and look at non-standard ones)
  • in case, create a detailed logfile of this event using:
    /tracking/verbose 6
Should I be worried about it? how can I supress this warning?
You should not be doing that outside of a process. You can write a process, add it to your physics list, and change the track kinematics in the process. There is documentation for that in both the Application Developers Guide and the Toolkit Developers Guide.
