I’m writing a simulation where in the main.cc file i start a multiple run (with different energy):
if ( ! ui ) {
// batch mode
UImanager->ApplyCommand("/control/execute init_vis.mac");
//UImanager->ApplyCommand("/control/execute Run.mac");
UImanager->ApplyCommand("/run/beamOn 1000000");
where Run.mac is:
/gun/energy 3.98 eV
/run/beamOn 1000000
/gun/energy 4.96 eV
/run/beamOn 1000000
For every of 50 runs, I want to write in an external file the value all the value of energies and entries in two different columns.
In the SteppingActions.cc file i created the NTuple:
void SteppingAction::UserSteppingAction(const G4Step* step)
auto volume_pre = step->GetPreStepPoint()->GetPhysicalVolume()->GetName();
auto volume_post = step->GetPostStepPoint()->GetPhysicalVolume()->GetName();
if ( step->GetTrack()->GetTrackID() == 1. && /*if particle is a optical photon... */
step->GetTrack()->GetTrackStatus() == fStopAndKill && /*if particle dies... */
volume_post == "SiPMPhys" /*... in SiPM. */) {
n_bounce = step->GetTrack()->GetCurrentStepNumber()/2;
stepTime = (step->GetTrack()->GetGlobalTime())*ns;
total_track = (step->GetTrack()->GetTrackLength())*cm;
analysisManager->FillNtupleIColumn(0, n_bounce);
analysisManager->FillNtupleDColumn(1, stepTime);
analysisManager->FillNtupleDColumn(2, total_track);
analysisManager->AddNtupleRow();
while in RunAction.cc file i create the root file for NTuple:
void RunAction::BeginOfRunAction(const G4Run* run)
G4cout << "### Run " << run->GetRunID() << " start." << G4endl;
//reset accumulables to their initial values
G4AccumulableManager* accumulableManager = G4AccumulableManager::Instance();
accumulableManager->Reset();
// Get analysis manager
// Open an output file
analysisManager->OpenFile("B3_result_histo.root");
void RunAction::EndOfRunAction(const G4Run* run)
// save histograms & ntuple
analysisManager->Write();
analysisManager->CloseFile();
G4int nofEvents = run->GetNumberOfEvent();
if (nofEvents == 0) return;
// Merge accumulables
accumulableManager->Merge();
//Print results
if (IsMaster())
G4cout
<< G4endl
<< "--------------------End of Global Run-----------------------"
<< G4endl
<< " The run was " << nofEvents << " events."
<< G4endl
<< "------------------------------------------------------------\t"
<< G4endl;
else
G4cout
<< G4endl
<< "-----------------End of Local Run Thread--------------------"
<< G4endl
<< G4endl
<< G4endl;
Now, I suppose, that here i need to create an external txt file, and save information about energies and entries, but How?
- I dind’t found any GetEntries() method for get the entries of Ntuple named
n_bounce
. How can I save the info about Entries?; - The txt file goes created on RunAction, right?
- How can i retrive the info about energy for each run and append the information?
