I wonder why I’m seeing only one or a few trajectories:
main
#include
using namespace std;#include “G4RunManager.hh”
#include “G4UImanager.hh”
#include “G4VisManager.hh”
#include “G4VisExecutive.hh”
#include “G4UIExecutive.hh”#include “construction.cc”
#include “physics.cc”
#include “action.cc”int main(int argc, char** argv)
G4RunManager *runManager = new G4RunManager();
runManager->SetUserInitialization(new MyDetectorConstruction());
runManager->SetUserInitialization(new MyPhysicsList());
runManager->SetUserInitialization(new MyActionInitialization());runManager->Initialize();
// batch mode
G4UIExecutive *ui = 0;
if(argc == 1)
ui = new G4UIExecutive(argc, argv);
}// graphical mode mode
//G4UIExecutive *ui = new G4UIExecutive(argc, argv);G4VisManager *visManager = new G4VisExecutive();
visManager->Initialize();G4UImanager *UImanager = G4UImanager::GetUIpointer();
if(ui)
UImanager->ApplyCommand(“/control/execute vis.mac”);
ui->SessionStart();
else
G4String command = "/control/execute- ";
G4String fileName = argv[1];
UImanager->ApplyCommand(command+fileName);
}return 0;
vis.mac
/vis/open OGL
/vis/enable
/vis/drawVolume
/vis/scene/add/axes
/vis/scene/add/eventID
/vis/scene/endOfEventAction accumulate 1000
/vis/reviewKeptEvents
This is the response I receive when running the program:
response
Registering graphics systems…ou have successfully registered the following graphics systems.
ASCIITree (ATree)
DAWNFILE (DAWNFILE)
G4HepRepFile (HepRepFile)
RayTracer (RayTracer)
VRML2FILE (VRML2FILE)
gMocrenFile (gMocrenFile)
OpenGLImmediateWin32 (OGLIWin32, OGLI)
OpenGLStoredWin32 (OGLSWin32, OGL, OGLS)Registering model factories…
ou have successfully registered the following model factories.
Registered model factories:
generic
drawByAttribute
drawByCharge
drawByOriginVolume
drawByParticleID
drawByEncounteredVolumeegistered models:
NoneRegistered filter factories:
attributeFilter
chargeFilter
originVolumeFilter
particleFilter
encounteredVolumeFilteregistered filters:
NoneYou have successfully registered the following user vis actions.
End of Run User Vis Actions: noneSome /vis commands (optionally) take a string to specify colour.
/vis/list" to see available colours.
ERROR: G4VisManager::IsValidView(): Current view is not valid.
ERROR: G4VisManager::PrintInvalidPointers:
Graphics system is OpenGLStoredWin32 but:
Null scene pointer. Use “/vis/drawVolume” or “/vis/scene/create”.
G4VisManager::Enable: WARNING: visualization remains disabled for
above reasons. Rectifying with valid vis commands will
automatically enable.
G4OpenGLViewer::DrawText: Not implemented for “viewer-0 (OpenGLStoredWin32)”
Called with G4Text: “x”
layout centre, offset (6,6)
4VMarker: position: (1050,0,0), world size: 0, screen size: 12
fill style: no fill
G4VisAttributes: visible, daughters visible, colour: (1,0,0,1) (red)
linestyle: solid, line width: 1, min line segments per circle: 3
drawing style: not forced, auxiliary edge visibility: not forced
line segments per circle: not forced.
time range: (-1e+100,1e+100)
G4AttValue pointer is zero, G4AttDef pointer is zero
/tracking/storeTrajectory 2
G4TrajectoriesModel:
Event ID (EventID): G4int
Run ID (RunID): G4int
G4SmoothTrajectory:
Track ID (ID): G4int
No. of points (NTP): G4int
PDG Encoding (PDG): G4int
Parent ID (PID): G4int
Particle Name (PN): G4String
G4SmoothTrajectoryPoint:
WARNING: Trajectory storing has been requested. This action may be
reversed with “/tracking/storeTrajectory 0”.
WARNING: The vis manager will keep up to 1000 events.
This may use a lot of memory.
It may be changed with, e.g., “/vis/scene/endOfEventAction accumulate 10”.
ERROR: G4VisCommandReviewKeptEvents::SetNewValue: No kept events,
or kept events not accessible.
/run/beamOn 100
===== Electromagnetic Physics Parameters ========PM effect enabled 1
nable creation and use of sampling tables 0
pply cuts on all EM processes 0
se general process 0
nable linear polarisation for gamma 0
nable sampling of quantum entanglement 0
-section factor for integral approach 0.8
in kinetic energy for tables 100 eV
ax kinetic energy for tables 100 TeV
umber of bins per decade of a table 7
erbose level 1
erbose level for worker thread 0
remsstrahlung energy threshold above which
primary e± is added to the list of secondary 100 TeV
remsstrahlung energy threshold above which primary
muon/hadron is added to the list of secondary 100 TeV
owest triplet kinetic energy 1 MeV
nable sampling of gamma linear polarisation 0
D gamma conversion model type 0
D gamma conversion model on isolated ion 0
ivermore data directory livermore===== Ionisation Parameters ========
tep function for e± (0.2, 1 mm)
tep function for muons/hadrons (0.2, 0.1 mm)
tep function for light ions (0.2, 0.1 mm)
tep function for general ions (0.2, 0.1 mm)
owest e+e- kinetic energy 1 keV
owest muon/hadron kinetic energy 1 keV
luctuations of dE/dx are enabled 1
se ICRU90 data 0
se built-in Birks satuaration 1
uild CSDA range enabled 0
se cut as a final range enabled 0
nable angular generator interface 0
ax kinetic energy for CSDA tables 1 GeV
ax kinetic energy for NIEL computation 0 eV
inear loss limit 0.01
ead data from file for e+e- pair production by mu 0===== Multiple Scattering Parameters ========
ype of msc step limit algorithm for e± 1
ype of msc step limit algorithm for muons/hadrons 0
sc lateral displacement for e± enabled 1
sc lateral displacement for muons and hadrons 0
rban msc model lateral displacement alg96 1
ange factor for msc step limit for e± 0.04
ange factor for msc step limit for muons/hadrons 0.2
eometry factor for msc step limitation of e± 2.5
afety factor for msc step limit for e± 0.6
kin parameter for msc step limitation of e± 1
ambda limit for msc step limit for e± 1 mm
se Mott correction for e- scattering 0
actor used for dynamic computation of angular
limit between single and multiple scattering 1
ixed angular limit between single
and multiple scattering 3.1416 rad
pper energy limit for e± multiple scattering 100 MeV
ype of electron single scattering model 0
ype of nuclear form-factor 1
creening factor 1phot: for gamma SubType=12 BuildTable=0
LambdaPrime table from 200 keV to 100 TeV in 61 bins
===== EM models for the G4Region DefaultRegionForTheWorld ======
LivermorePhElectric : Emin= 0 eV Emax= 100 TeV SauterGavrila Fluocompt: for gamma SubType=13 BuildTable=1
Lambda table from 100 eV to 1 MeV, 7 bins/decade, spline: 1
LambdaPrime table from 1 MeV to 100 TeV in 56 bins
Klein-Nishina : Emin= 0 eV Emax= 100 TeVconv: for gamma SubType=14 BuildTable=1
Lambda table from 1.022 MeV to 100 TeV, 18 bins/decade, spline: 1
BetheHeitlerLPM : Emin= 0 eV Emax= 100 TeV ModifiedTsaiRayl: for gamma SubType=11 BuildTable=1
Lambda table from 100 eV to 100 keV, 7 bins/decade, spline: 0
LambdaPrime table from 100 keV to 100 TeV in 63 bins
LivermoreRayleigh : Emin= 0 eV Emax= 100 TeV CullenGeneratormsc: for e- SubType= 10
UrbanMsc : Emin= 0 eV Emax= 100 MeV Nbins=42 100 eV - 100 MeV
StepLim=UseSafety Rfact=0.04 Gfact=2.5 Sfact=0.6 DispFlag:1 Skin=1 Llim=1 mm
WentzelVIUni : Emin= 100 MeV Emax= 100 TeV Nbins=42 100 MeV - 100 TeV
StepLim=UseSafety Rfact=0.04 Gfact=2.5 Sfact=0.6 DispFlag:1 Skin=1 Llim=1 mmeIoni: for e- XStype:1 SubType=2
dE/dx and range tables from 100 eV to 100 TeV in 84 bins
Lambda tables from threshold to 100 TeV, 7 bins/decade, spline: 1
StepFunction=(0.2, 1 mm), integ: 1, fluct: 1, linLossLim= 0.01
MollerBhabha : Emin= 0 eV Emax= 100 TeVeBrem: for e- XStype:4 SubType=3
LPM flag: 1 for E > 1 GeV, VertexHighEnergyTh(GeV)= 100000
eBremSB : Emin= 0 eV Emax= 1 GeV ModifiedTsai
eBremLPM : Emin= 1 GeV Emax= 100 TeV ModifiedTsaiCoulombScat: for e- XStype:1 SubType=1 BuildTable=1
Lambda table from 100 MeV to 100 TeV, 7 bins/decade, spline: 0
ThetaMin(p) < Theta(degree) < 180; pLimit(GeV^1)= 0.139531
eCoulombScattering : Emin= 100 MeV Emax= 100 TeVmsc: for e+ SubType= 10
StepLim=UseSafety Rfact=0.04 Gfact=2.5 Sfact=0.6 DispFlag:1 Skin=1 Llim=1 mmeIoni: for e+ XStype:1 SubType=2
MollerBhabha : Emin= 0 eV Emax= 100 TeVeBrem: for e+ XStype:4 SubType=3
eBremLPM : Emin= 1 GeV Emax= 100 TeV ModifiedTsaiannihil: for e+ XStype:2 SubType=5 BuildTable=0
eplus2gg : Emin= 0 eV Emax= 100 TeVCoulombScat: for e+ XStype:1 SubType=1 BuildTable=1
eCoulombScattering : Emin= 100 MeV Emax= 100 TeVmsc: for proton SubType= 10
WentzelVIUni : Emin= 0 eV Emax= 100 TeV Nbins=84 100 eV - 100 TeV
StepLim=Minimal Rfact=0.2 Gfact=2.5 Sfact=0.6 DispFlag:0 Skin=1 Llim=1 mmhIoni: for proton XStype:1 SubType=2
StepFunction=(0.2, 0.1 mm), integ: 1, fluct: 1, linLossLim= 0.01
Bragg : Emin= 0 eV Emax= 2 MeV
BetheBloch : Emin= 2 MeV Emax= 100 TeVhBrems: for proton XStype:1 SubType=3
Lambda tables from threshold to 100 TeV, 7 bins/decade, spline: 0
hBrem : Emin= 0 eV Emax= 100 TeV ModifiedMephihPairProd: for proton XStype:1 SubType=4
Sampling table 17x1001; from 7.50618 GeV to 100 TeV
hPairProd : Emin= 0 eV Emax= 100 TeV ModifiedMephiCoulombScat: for proton XStype:1 SubType=1 BuildTable=1
Lambda table from threshold to 100 TeV, 7 bins/decade, spline: 0
eCoulombScattering : Emin= 0 eV Emax= 100 TeVmsc: for GenericIon SubType= 10
UrbanMsc : Emin= 0 eV Emax= 100 TeV
StepLim=Minimal Rfact=0.2 Gfact=2.5 Sfact=0.6 DispFlag:0 Skin=1 Llim=1 mmionIoni: for GenericIon XStype:1 SubType=2
StepFunction=(0.2, 0.1 mm), integ: 1, fluct: 1, linLossLim= 0.02
Stopping Power data for 17 ion/material pairs
BraggIon : Emin= 0 eV Emax= 2 MeV
BetheBloch : Emin= 2 MeV Emax= 100 TeVmsc: for alpha SubType= 10
StepLim=Minimal Rfact=0.2 Gfact=2.5 Sfact=0.6 DispFlag:0 Skin=1 Llim=1 mmionIoni: for alpha XStype:1 SubType=2
BraggIon : Emin= 0 eV Emax=7.9452 MeV
BetheBloch : Emin=7.9452 MeV Emax= 100 TeVmsc: for anti_proton SubType= 10
StepLim=Minimal Rfact=0.2 Gfact=2.5 Sfact=0.6 DispFlag:0 Skin=1 Llim=1 mmhIoni: for anti_proton XStype:1 SubType=2
ICRU73QO : Emin= 0 eV Emax= 2 MeV
BetheBloch : Emin= 2 MeV Emax= 100 TeVhBrems: for anti_proton XStype:1 SubType=3
hBrem : Emin= 0 eV Emax= 100 TeV ModifiedMephihPairProd: for anti_proton XStype:1 SubType=4
hPairProd : Emin= 0 eV Emax= 100 TeV ModifiedMephiCoulombScat: for anti_proton XStype:1 SubType=1 BuildTable=1
eCoulombScattering : Emin= 0 eV Emax= 100 TeVmsc: for kaon+ SubType= 10
StepLim=Minimal Rfact=0.2 Gfact=2.5 Sfact=0.6 DispFlag:0 Skin=1 Llim=1 mmhIoni: for kaon+ XStype:1 SubType=2
Bragg : Emin= 0 eV Emax=1.05231 MeV
BetheBloch : Emin=1.05231 MeV Emax= 100 TeVhBrems: for kaon+ XStype:1 SubType=3
hBrem : Emin= 0 eV Emax= 100 TeV ModifiedMephihPairProd: for kaon+ XStype:1 SubType=4
Sampling table 18x1001; from 3.94942 GeV to 100 TeV
hPairProd : Emin= 0 eV Emax= 100 TeV ModifiedMephiCoulombScat: for kaon+ XStype:1 SubType=1 BuildTable=1
eCoulombScattering : Emin= 0 eV Emax= 100 TeVmsc: for kaon- SubType= 10
StepLim=Minimal Rfact=0.2 Gfact=2.5 Sfact=0.6 DispFlag:0 Skin=1 Llim=1 mmhIoni: for kaon- XStype:1 SubType=2
ICRU73QO : Emin= 0 eV Emax=1.05231 MeV
BetheBloch : Emin=1.05231 MeV Emax= 100 TeVhBrems: for kaon- XStype:1 SubType=3
hBrem : Emin= 0 eV Emax= 100 TeV ModifiedMephihPairProd: for kaon- XStype:1 SubType=4
hPairProd : Emin= 0 eV Emax= 100 TeV ModifiedMephiCoulombScat: for kaon- XStype:1 SubType=1 BuildTable=1
Used Lambda table of kaon+
eCoulombScattering : Emin= 0 eV Emax= 100 TeVmsc: for mu+ SubType= 10
StepLim=Minimal Rfact=0.2 Gfact=2.5 Sfact=0.6 DispFlag:0 Skin=1 Llim=1 mmmuIoni: for mu+ XStype:1 SubType=2
Bragg : Emin= 0 eV Emax= 200 keV
BetheBloch : Emin= 200 keV Emax= 1 GeV
MuBetheBloch : Emin= 1 GeV Emax= 100 TeVmuBrems: for mu+ XStype:1 SubType=3
MuBrem : Emin= 0 eV Emax= 100 TeV ModifiedMephimuPairProd: for mu+ XStype:1 SubType=4
Sampling table 21x1001; from 1 GeV to 100 TeV
muPairProd : Emin= 0 eV Emax= 100 TeV ModifiedMephiCoulombScat: for mu+ XStype:1 SubType=1 BuildTable=1
eCoulombScattering : Emin= 0 eV Emax= 100 TeVmsc: for mu- SubType= 10
StepLim=Minimal Rfact=0.2 Gfact=2.5 Sfact=0.6 DispFlag:0 Skin=1 Llim=1 mmmuIoni: for mu- XStype:1 SubType=2
ICRU73QO : Emin= 0 eV Emax= 200 keV
MuBetheBloch : Emin= 1 GeV Emax= 100 TeVmuBrems: for mu- XStype:1 SubType=3
MuBrem : Emin= 0 eV Emax= 100 TeV ModifiedMephimuPairProd: for mu- XStype:1 SubType=4
muPairProd : Emin= 0 eV Emax= 100 TeV ModifiedMephiCoulombScat: for mu- XStype:1 SubType=1 BuildTable=1
Used Lambda table of mu+
eCoulombScattering : Emin= 0 eV Emax= 100 TeVmsc: for pi+ SubType= 10
StepLim=Minimal Rfact=0.2 Gfact=2.5 Sfact=0.6 DispFlag:0 Skin=1 Llim=1 mmhIoni: for pi+ XStype:1 SubType=2
Bragg : Emin= 0 eV Emax=297.505 keV
BetheBloch : Emin=297.505 keV Emax= 100 TeVhBrems: for pi+ XStype:1 SubType=3
hBrem : Emin= 0 eV Emax= 100 TeV ModifiedMephihPairProd: for pi+ XStype:1 SubType=4
Sampling table 20x1001; from 1.11656 GeV to 100 TeV
hPairProd : Emin= 0 eV Emax= 100 TeV ModifiedMephiCoulombScat: for pi+ XStype:1 SubType=1 BuildTable=1
eCoulombScattering : Emin= 0 eV Emax= 100 TeVmsc: for pi- SubType= 10
StepLim=Minimal Rfact=0.2 Gfact=2.5 Sfact=0.6 DispFlag:0 Skin=1 Llim=1 mmhIoni: for pi- XStype:1 SubType=2
ICRU73QO : Emin= 0 eV Emax=297.505 keV
BetheBloch : Emin=297.505 keV Emax= 100 TeVhBrems: for pi- XStype:1 SubType=3
hBrem : Emin= 0 eV Emax= 100 TeV ModifiedMephihPairProd: for pi- XStype:1 SubType=4
hPairProd : Emin= 0 eV Emax= 100 TeV ModifiedMephiCoulombScat: for pi- XStype:1 SubType=1 BuildTable=1
Used Lambda table of pi+
G4VisManager: Using G4TrajectoryDrawByCharge as fallback trajectory model.
See commands in /vis/modeling/trajectories/ for other options.
100 events have been kept for refreshing and/or reviewing.
“/vis/reviewKeptEvents” to review them one by one.
“/vis/enable”, then “/vis/viewer/flush” or “/vis/viewer/rebuild” to see them accumulated.
I attached two images. The one which shows the scenario directly at the beginning:
the other one after /run/beamOn 100:
