I have a simulation where I am investigating electron bremsstrahlung. Of course, only a handful of the actual events produce any photons (generally about 1 in every 1000). I want to produce a figure where I only see tracks for which a photon was produced, is there an easy way to do this that won’t require me to manually sort through every event?
Thank you for the reply, I have tried the trajectory filtering but the problem is I can’t seem to filter an entire event based on one of the particles within the event. When a photon is produced I want to see the electron trajectory as well.
Oh, that’s different from what you described (“I want to produce a figure where I only see tracks for which a photon was produced”). I believe there’s a way, for instance in your stepping action, to “flag” an event for display. If you put a check in your stepping action to see if a secondary is a photon, then you should be able to do this. The same chapter in the Developer’s guide should talk about this.
