Hi all, I think I’ve managed to pinpoint a surprising error that has to do with opticalphoton
reflection off of a dielectric_metal
interface. I’m not sure if this is a bug, but I wanted to create a topic here because this has been a big headache to figure out. I am running Geant4 10.07.p02.
The geometry is this: a 2cm x 2cm x 2cm cube of cerium bromide with refractive index n = 2.09, and a 1mm thick shell of aluminum around the material with one end open. There is a 1mm vacuum (low-density hydrogen) gap between the two. The geometries are not overlapping.
When I specify only the REALRINDEX
and IMAGINARYRINDEX
for the aluminum (from Cheng et al. 2016), and then wrap the aluminum shell in a G4LogicalSkinSurface
, reflection and absorption occur as one would expect. Below is the code used to attach the skin surface, and a screenshot of the expected behavior.
void attachAlOpticalSurface(G4LogicalVolume* lv)
static G4OpticalSurface* as = nullptr;
if (as == nullptr) {
as = new G4OpticalSurface("al_optical_surf");
as->SetModel(unified);
as->SetType(dielectric_metal);
as->SetFinish(polished);
as->SetMaterialPropertiesTable(
G4Material::GetMaterial(OptDebugMaterials::kAL)->
GetMaterialPropertiesTable());
(void) new G4LogicalSkinSurface("al_skin_surf", lv, as);
An
opticalphoton
is launched from the center of the cerium bromide cube and has multiple Spike
reflections off of the aluminum until it is ultimately absorbed.
Now, when I also specify the RINDEX
for the aluminum and its G4OpticalSurface
, I consistently receive the following TRACK003
error that the photon is traveling at a velocity greater than c_light and its momentum/energy change is invalid, accompanied by a step length of 0 femtometers:
### Run 1 starts.
G4WT1 > ### Run 1 starts on worker thread 1.
G4WT0 > ### Run 1 starts on worker thread 0.
G4WT1 > G4ParticleChange::CheckIt : the velocity is greater than c_light !!
G4WT0 > Thread-local run terminated.
G4WT1 > Velocity: 2.94179
G4WT1 > opticalphoton E=3e-06 pos=-0.0105, 0.000304477, -0.00273335
G4WT0 > Run Summary
G4WT1 > -----------------------------------------------
G4WT0 > Number of events processed : 0
G4WT1 > G4ParticleChange Information
G4WT0 > User=0.000000s Real=0.000003s Sys=0.000000s [Cpu=0.0%]
G4WT1 > # of 2ndaries : 0
G4WT1 > Energy Deposit (MeV): 0
G4WT1 > Non-ionizing Energy Deposit (MeV): 0
G4WT1 > Track Status : Alive
G4WT1 > True Path Length (mm) : 0
G4WT1 > Stepping Control : 0
G4WT1 > First Step In the voulme :
G4WT1 > Mass (GeV) : 0
G4WT1 > Charge (eplus) : 0
G4WT1 > MagneticMoment : 0
G4WT1 > : = 0*[e hbar]/[2 m]
G4WT1 > Position - x (mm) : -10.5
G4WT1 > Position - y (mm) : 0.304
G4WT1 > Position - z (mm) : -2.73
G4WT1 > Time (ns) : 0.139
G4WT1 > Proper Time (ns) : 0
G4WT1 > Momentum Direct - x : 0.983
G4WT1 > Momentum Direct - y : 0.0204
G4WT1 > Momentum Direct - z : -0.183
G4WT1 > Kinetic Energy (MeV): 3e-06
G4WT1 > Velocity (/c): 2.94
G4WT1 > Polarization - x : -0.184
G4WT1 > Polarization - y : 0.109
G4WT1 > Polarization - z : -0.977
G4WT1 > Touchable (pointer) : 0x7f9df0cc3a10
G4WT1 >
*** G4Exception : TRACK003
issued by : G4ParticleChange::CheckIt()
momentum, energy, and/or time was illegal
*** Event Must Be Aborted ***
G4WT1 > G4Track (0x7f9df0cc3530) - track ID = 1, parent ID = 0
G4WT1 > Particle type : opticalphoton - creator process : not available
G4WT1 > Kinetic energy : 3 eV - Momentum direction : (0.982861,0.0204087,-0.183213)
G4WT1 > Step length : 0 fm - total energy deposit : 0 eV
G4WT1 > Pre-step point : (-10.5,0.304477,-2.73335) - Physical volume : al_phys (aluminum)
G4WT1 > - defined by : Transportation - step status : 1
G4WT1 > Post-step point : (-10.5,0.304477,-2.73335) - Physical volume : al_phys (aluminum)
G4WT1 > *** Note: Step information might not be properly updated.
G4WT1 >
G4WT1 > Last Step In the voulme :
G4WT1 >
G4WT1 > Post-step point : (-10.5,0.304477,-2.73335) - Physical volume : World (vacuum)
G4WT1 >
G4WT1 > Thread-local run terminated.
G4WT1 > Run Summary
G4WT1 > Number of events processed : 1
G4WT1 > User=0.050000s Real=0.048872s Sys=0.010000s [Cpu=122.8%]
Run terminated.
Run Summary
User=0.070000s Real=0.069784s Sys=0.010000s [Cpu=114.6%]
Again, I’m not sure if this is a bug or just unexpected (but appropriate) behavior.
For now the solution is to not specify the RINDEX
of dielectric_metal
interfaces and only specify REALRINDEX
and IMAGINARYRINDEX
. This being said, I think this surprising behavior warrants further investigation and discussion.
