Hi all,
I want to count the primary particles that succeed in passing through my sensitive detector, but I get a number greater than the number of initial particles !
As you will see in this tracking output ;
* G4Track Information: Particle = e-, Track ID = 1, Parent ID = 0
Step# X(mm) Y(mm) Z(mm) KinE(MeV) dE(MeV) StepLeng TrackLeng NextVolume ProcName
0 0 0 -950 10 0 0 0 World initStep
1 0 0 -902 10 1.27e-24 48 48 Target Transportation
2 0 0 -900 8.89 1.11 2.1 50.1 World Transportation
3 0 0 -900 8.89 0 0 50.1 Target Transportation
4 -1.91 0.219 -902 6.95 1.94 3.04 53.1 World Transportation
5 -162 -17.5 -1e+03 6.95 4.81e-24 189 242 OutOfWorld Transportation
the 2nd step says that the next volume is the WorldVolume while this primary particle will change direction in step 3, and will propagate the whole step 4 in my sensitive detector before leaving it in step 5.
So it counts twice.
What can I do to eliminate these steps? (I used the IsLastStepInVolume() condition but I get the same result, as the next volume information remains the same.)
Is there a better way to count particles at a volume boundary ?
Thank you !
Younes
