Dear all, I’m a beginner. I’ve just finally installed successfully Geant4, because I need to simulate a positron beam 45GeV, hitting a Carbonium fixed target having a setted thickness. I just need to count, after the target how many e-e+ -> e+e- and how many e-e+ -> mu+ mu- I got.
Can someoune help me how to start? I never made a Geant4 simulation…
a simplest example is $G4INSTALL/example/extended/hadronic/Hadr01
VI
Hi @civanch thank you for your reply.
First of all, I tried to compile the example. I copied all the files in the directory
to the directoryC:/Hadr01
then I tried to build the .exe file in this way:**C:\Users\faust>cd c:/Hadr01**
** c:\Hadr01>mkdir Hadr01-build**
** c:\Hadr01>cd Hadr01-build**
** c:\Hadr01\Hadr01-build>cmake -DGeant4_DIR=“C:/Program Files/geant4_10_05_p01_bin-install/lib/Geant4-10.5.1” “C:/Hadr01”**
-- Building for: Visual Studio 15 2017
-- Selecting Windows SDK version 10.0.17763.0 to target Windows 10.0.17134.
-- The C compiler identification is MSVC 19.16.27031.1
-- The CXX compiler identification is MSVC 19.16.27031.1
-- Check for working C compiler: C:/Program Files (x86)/Microsoft Visual Studio/2017/WDExpress/VC/Tools/MSVC/14.16.27023/bin/Hostx86/x86/cl.exe
-- Check for working C compiler: C:/Program Files (x86)/Microsoft Visual Studio/2017/WDExpress/VC/Tools/MSVC/14.16.27023/bin/Hostx86/x86/cl.exe -- works
-- Check for working CXX compiler: C:/Program Files (x86)/Microsoft Visual Studio/2017/WDExpress/VC/Tools/MSVC/14.16.27023/bin/Hostx86/x86/cl.exe
-- Check for working CXX compiler: C:/Program Files (x86)/Microsoft Visual Studio/2017/WDExpress/VC/Tools/MSVC/14.16.27023/bin/Hostx86/x86/cl.exe -- works
-- Configuring done
-- Generating done
-- Build files have been written to: C:/Hadr01/Hadr01-build
**c:\Hadr01\Hadr01-build>cmake --build . --config Release**
Microsoft (R) Build Engine versione 15.9.21+g9802d43bc3 per .NET Framework
Copyright (C) Microsoft Corporation. Tutti i diritti sono riservati.
Checking Build System
Building Custom Rule C:/Hadr01/CMakeLists.txt
Hadr01.cc
CheckVolumeSD.cc
DetectorConstruction.cc
DetectorMessenger.cc
EventAction.cc
EventActionMessenger.cc
Histo.cc
HistoManager.cc
HistoMessenger.cc
PhysicsList.cc
PhysicsListMessenger.cc
PrimaryGeneratorAction.cc
RunAction.cc
StackingAction.cc
StackingMessenger.cc
TargetSD.cc
Generazione del codice in corso...
Hadr01.vcxproj -> C:\Hadr01\Hadr01-build\Release\Hadr01.exe
**c:\Hadr01\Hadr01-build>cd Release**
** c:\Hadr01\Hadr01-build\Release>Hadr01.exe**
Available UI session types: [ Win32, GAG, csh ]
*** ExceptionHandler is not defined ***
*** G4Exception : UI0002
issued by : G4UIExecutive::G4UIExecutive()
Specified session type is not build in your system,
or no session type is specified.
A fallback session type is used.
-------- WWWW ------- G4Exception-END -------- WWWW -------
Geant4 version Name: geant4-10-05-patch-01 (17-April-2019)
: IEEE-TNS 53 (2006), 270-278
: NIM A 835 (2016), 186-225
WWW : http://geant4.org/
Current available graphics systems are:
ASCIITree (ATree)
DAWNFILE (DAWNFILE)
G4HepRep (HepRepXML)
G4HepRepFile (HepRepFile)
RayTracer (RayTracer)
VRML1FILE (VRML1FILE)
VRML2FILE (VRML2FILE)
gMocrenFile (gMocrenFile)
OpenGLImmediateWin32 (OGLIWin32, OGLI)
OpenGLStoredWin32 (OGLSWin32, OGL, OGLS)
Registered model factories:
generic
drawByAttribute
drawByCharge
drawByOriginVolume
drawByParticleID
drawByEncounteredVolume
Registered filter factories:
attributeFilter
chargeFilter
originVolumeFilter
particleFilter
encounteredVolumeFilter
PreInit>
but I can’t read information about particles…
Moreover…I need to modify the example (I need a positron beam 45GeV hitting a C fixed lenght target)
I found thehadr01.in
file in$G4INSTALL/example/extended/hadronic/Hadr01
directory that is#================================================
Macro file for hadr01
06.06.2006 V.Ivanchneko
/control/verbose 2
/run/verbose 2
/tracking/verbose 0/testhadr/TargetMat G4_Al
/testhadr/TargetRadius 1 cm
/testhadr/TargetLength 10 cm
/testhadr/NumberDivZ 100
/testhadr/PrintModulo 10/run/setCut 1 mm
/testhadr/Physics QBBC/run/initialize
/gun/particle proton
/gun/energy 3. GeV
/run/beamOn 100
then…is it enough to modify this file in this way ? (In bold my changes)
/control/verbose 2
/run/verbose 2
/tracking/verbose 0
/testhadr/TargetMat G4_C
/testhadr/TargetLength 2 cm
/run/setCut 1 mm
/run/initialize
/gun/particle positron
/gun/energy 45. GeV
/run/beamOn 100
