I was trying to follow the official manual: https:///geant4-userdoc.web.cern.ch/UsersGuides/ForApplicationDeveloper/html/Detector/commandScore.html#filling-1-d-histogram to use a scorer to fill a 1D histogram defined by G4Analysis. But I got the following error message:
*** G4Exception : Analysis_W011
issued by : G4THnManager::GetH1
histogram 1 does not exist.
when I run
$ G4RUN_MANAGER_TYPE=Serial ./build/tiny detector.txt radiate.txt
where tiny is the executable compiled from tiny.cc attached to this post, detector.txt defines a germanium detector, radiate.txt is the mac file, where I used the following macros trying to realize what was intended:
/score/create/realWorldLogVol HPGe(S)
/score/quantity/energyDeposit hE keV
/score/close
/analysis/h1/create hE "energy deposition" 300 0 3000 keV
/score/fill1D 1 HPGe(S) hE
CMakeLists.txt
is also attached if you need to compile the tiny.cc
file.
Your help is appreciated.
Thanks, Jing
I am sorry that I had to break the syntax (the leading [) for the following links because a new user can only post with two links inside.
tiny.cc (3.4 KB)
CMakeLists.txt (326 Bytes)
detector.txt|attachment](upload://gR0pMsCVmhj27TWbDqTf2DeuHhy.txt) (767 Bytes)
radiate.txt|attachment](upload://nhrGLd7gTC8KazrGcE80g6AMAdA.txt) (717 Bytes)
To repeat the problem, run
$ cd /path/to/tiny
$ mkdir build
$ cd build
$ ccmake ..
$ make
$ cd ..
