Hi all
I’m using ASCII file to construct the detector.
After a successful BeamOn()
, I modify the ASCII file to change the geometry, and call:
runManager->ReinitializeGeometry(true);
runManager->GeometryHasBeenModified();
Then I call BeamOn()
again and the program is aborted with a exception saying
Rotation matrix repeated… R00
Where R00 is a parameter I defined in the ASCII file to build the geometry.
I think this is indicating that when runManager
calls the Construct()
again in the second BeamOn()
, the G4tgbVolumeMgr
reads the ASCII again and tries to register the same parameter R00, causing the repeated parameter abort.
If I don’t call ReinitializeGeometry(true);
and just
instead, the abort will not happen, however, nor will the geometry modification.
I’ve browsed some G4tgbVolumeMgr
source code to find ways delete these parameters and tried deleting G4tgbVolumeMgr
pointer at the beginning of Construct()
. Unfortunately, these attempts failed.
Therefore, I am asking here for help. Did I make any mistake when changing the geometry? It’s there anything I can do to avoid this repeated parameter abort?
PS: My goal is to implement detector geometry modification without recompiling or even restarting the executable.
