Hello, I am trying to simulate scintillation photons in liquid argon in my geant4 simulation, but I seem to be having some problems. I don’t seem to get the expected amount of scintillation photons based on the parameters I set.
I defined my LAr material as follows:
as I understand it, scintillation yield is defined as the expected number of scintillation photons created by a given energy deposit by an electron in a material.
In my simulation I fire a 1 MeV electron directly in the center of my LAr detector(so that it deposits all of its energy there ,I checked and it does indeed do that), and as I set the SCINTILLATIONYIELD to 51000, I expect to see 51000 scintillation photons per event (because I set RESOLUTIONSCALE = 0 and birks constant = 0).
However, I still get a varying number of scintillation photons per event, mostly less than 51000.
I am calculating the amount of scintillation photons per event in two ways, which disagree with each other. The first is using some code I saw online:
In my stepping action -
auto proc_man =
aStep->GetTrack()->GetDynamicParticle()->GetParticleDefinition()->GetProcessManager();
G4ProcessVector* proc_vec = proc_man->GetPostStepProcessVector(typeDoIt);
G4int n_proc = proc_vec->entries();
G4int n_scint = 0;
G4int n_cer = 0;
for(G4int i = 0; i < n_proc; ++i)
G4String proc_name = (*proc_vec)[i]->GetProcessName();
if(proc_name.compare("Cerenkov") == 0)
auto cer = (G4Cerenkov*) (*proc_vec)[i];
n_cer = cer->GetNumPhotons();
else if(proc_name.compare("Scintillation") == 0)
auto scint = (G4Scintillation*) (*proc_vec)[i];
n_scint = scint->GetNumPhotons();
if(n_cer > 0 || n_scint > 0){
fEventAction->nScint += n_scint;
fEventAction->nCher += n_cer;
the second method is tracking each photon individually, again in my stepping action-
static G4ParticleDefinition* opticalphoton = G4OpticalPhoton::OpticalPhotonDefinition();
const G4ParticleDefinition* particleDef =
aStep->GetTrack()->GetDynamicParticle()->GetParticleDefinition();
if(particleDef == opticalphoton){
G4Track* track = aStep->GetTrack();
if(track->GetCreatorProcess()->GetProcessName() == “Scintillation”){
if (aStep->GetTrack()->GetCurrentStepNumber() == 1){
fEventAction->numPhotons+=1;
I also tried to change my material from G4_lAr to something else, but then for some reason i get 0 scintillation photons.
I would appreciate your help with these issues.
Aviv
