When trying to calibrate the software, an error message appears saying that the project files are invalid and that they cannot be calibrated.
What version of Geant4 and CMake are you using, and what error messages are being printed?
[cmake-3.19.3-win32-x86.zip]
and
Geant 4 10.7
The error messages are;
CMAKE_AR
CMAKE_BACKWARD_COMPATIBILITY
CMAKE_CONFIGURATION_TYPES
CMAKE_INSTALL_PREFIX
EXECUTABLE_OUTPUT_PATH
LIBRARY_OUTPUT_PATH
What does it say in relation to these and why they are causing an error? CMake should be printing output at the terminal or in the cmake-gui panel. We need to see what those say.
Thanks for the info. The error is down to the wrong source directory being passed to CMake. In the above, it’s
C:/Users/***/Documents/Geant4 Extracted/geant4_10_07/source
where it should be
Please see the Installation on Windows Guide for additional info here.
Okay thank you I will try this resolution and get back to you. Thank you for your help
I have just tried it quickly and the configuration has worked. Thanks.
