hello,
can anyone help me to remove the errors
Hi. It looks like you are using code based on a very old example. More than 15 years ago - maybe 20 - we provided and recommended G4VisExecutive as the concrete vis manager to obviate the need for users to write their own vis manager (MyVisManager). In that time there has been a significant major release, namely Geant4 10-series, and some interfaces changed. Only a few, but maybe enough to explain why you are getting problems with MyVisManager and MyUserScorerWriter.
Have a look at the 10-series release notes:
http://geant4-data.web.cern.ch/geant4-data/ReleaseNotes/ReleaseNotes4.10.0.html#3.
It mentions scorers under Geometry. Not sure exactly how that impacts your application.
Have a look at our current examples - they all use G4VisExecutive. And for scorers, maybe examples/extended/parallel/ThreadsafeScorers
will help.
thank you.
does that mean i have to replace both classes MyVisManager and MyUserScorerWriter with another one ?
Replace MyVisManger with G4VisExecutive - yes.
Not sure about MyUserScorerWriter - maybe more an adaptation for the 10-series.
G4THitsMap is std::map<G4int,G4StatDouble*>, you should correct your code as such.
std::map<G4int, G4double*> * score = msMapItr->second->GetMap();
how can i correct it?
