I built a box made of G4_Si with (x,y,z) full dimensions (0.3um, 0.3um, 0.5um). I shoot an alpha particle along z towards the center of the volume. I attached to that volume a customized primitive scorer from which I access info. The physics is QGSP_BIC_EMY.
When applying a production cut of 1um, I get a few hundreds of delta electrons (as I would expect). When I apply a production cut of 1mm, there are no electrons produced. Given that in the volume I described above, the safety would be always smaller than 1um, why does the production cut prevail and there are no electrons produced? I would expect approximately the same number of electrons as with the 1um cut.
It’s 7MeV. I tried also at 60MeV, with the same result. For higher energies the number of delta electrons produced with 1um cut is of course smaller than for lower energies.
New edit: I did the same test for 10.03.p03 and for 10.06.p02, with the same result.
1- the 2 concepts are independent. It is not true that, ‘on fly’, we would recompute currentCut = min(cut, safety).
2- If you run the attached macro, you will read that, for an alpha (7 MeV) on silicon, the maximum energy transferable is ~ 4 keV. Cut = 1 mm gives min delta ray energy = ~ 550 keV. Therefore there are no delta rays produced : the cross section is null. gdedes.mac.txt (313 Bytes)
Case3, firgure 3 even showcases that. That’s also what I understand (maybe wrongly) when I read the the respective part of the new manual:
There’s also the statement “The particle is stacked if range > min(cut,safety)”. This is stated under the case “ApplyCut in ON”. Does the user need to set this flag ON? I did from the physics list and I can see in the tracking that this flag is then true, but still the result is the same.
Maybe I misunderstood what I’m reading in the manual. If in any case currentCut = min(cut, safety) is not recomputed as I interpret the documentation, is there a way to do activate this?
thanks to recall me this old story ( 15 years ago …)
I tried to redo the exercice with attached macro ( subcutoff.mac) but result is the opposite of what I expected : d-rays seems to be generated below safety !
We will have to submit a bug report. subcutoff.mac.txt (607 Bytes)
1- Yes, I will make a bug report, but after the December release.
2- My answer was too quick. The sub cutoff production possibility exists, but it is optional, and governed by the 2 commands :
/process/eLoss/subsec true World
/process/eLoss/minsubsec 0.01
where minsubsec is the ratio new_subCut/defaultCut
Then the code will (should !) generate d-rays with range > max (new_subCut, safety)
I’m reviving this after some testing. Actually I can’t make it work properly. I found out that the value next to the /process/eLoss/subsec true needs to be the name of a region. In my simulation I have two regions, one of them being the DefaultRegionForTheWorld and a second one, which is my custom region.
I run 1 particle and switch the tracking/verbose to 1 in order to get some information printed out. I set the cuts to 1*mm and without the /process/eLoss/subsec and the /process/eLoss/minsubsec no delta-rays are created. Then I use the commands and start changing the argument of the /process/eLoss/minsubsec to lower and lower fractions. No delta rays will be created until I reach a value (0.001 for my custom region and 0.00001 for the DefaultRegionForTheWorld) when there’s a crash every time a primary enters the region specified by the /process/eLoss/subsec. I tried both 10.06.2 and 10.03.03
