Some problems in G4AnalysisManager
Hello everyone. I made some bugs in the .mac file.
I am asking for help how to solve it.
/run/initialize
/gun/particle e-
/gun/energy 12 eV
/run/beamOn 100000
/gun/energy 62 eV
/run/beamOn 100000
If I call the /run/beamOn twice times, it would come out a warning that wouldn’t happen when I call the /run/beamOn just for once.
*** G4Exception : Analysis_W001
      issued by : G4TNtupleManager<NT,FT>::FillNtupleTColumn
Ntuple 0 does not exist.
Here copy my RunAction code
RunAction::RunAction()
	CreateRoot();
void RunAction::CreateRoot()
	G4AnalysisManager* man = G4AnalysisManager::Instance();
	man->OpenFile("output.root");
	man->CreateNtuple("Benchmark", "Benchmark");
	man->CreateNtupleIColumn("fEvent");
	man->FinishNtuple(0);
	man->CreateNtuple("array", "array");
	man->CreateNtupleIColumn("X");
	man->FinishNtuple(1);
void RunAction::EndOfRunAction(const G4Run* run)
	man->Write();
	man->CloseFile();
If I should add something more to determine when to close the File?
Thank you for your attention!
By the way, I learn this kind of mac command which “/run/beamOn” for twice from the DNA example like range,spower and so on, but I don’t know why it can’t work here.
Hello everyone, I find out the reason that once I run the EndofRun, the analysismanager should be end. One of the correct methods is that you should learn from the example to make a run class to merge the counters and write it into .txt file. Thank you for your watching!
