I have finished my particle detector and the photons which I am interacting with it, however, the actual simulation of around 10-100 million particles would take around 2 weeks using my computer. Looking at my thread utilization I can see I am only using 1 thread (out of 12 available). How can I use multiple cores at one time? I have have access to a cluster where I can use north of 50 cores to help run this faster. Please direct me to where this can be done because I could not find any documentation.
when you build geant4: cmake -DGEANT4_BUILD_MULTITHREADED=ON ...
Is there anyway to change this once it is already built?
Actually just checked my original install and it would appear that I had had that option turned on originally. Not sure what to do here as my simulation is only using one thread when I am running a simulation
Have a look at examples/basic/B1/init_vis.mac
How are you constructing your run manager for this simulation? Is it G4RunManager
or G4MTRunManager
You should also consider upgrading from 10.5 to 10.7 as there is easier MT support/use in the newer version.
in your screenshot on the right, you find the note: “Command below should be a single line”
in your screenshot on the left, you find multiple warnings: “command not found”, as if you copy/pasted the command not as a single line, but as several independent lines.
make sure to have one single line, starting with cmake and ending with the path of the source code.
cmake -DCMAKE_BUILD_MULTITHREADED=ON (...other options...) ../geant10.05.p01
