Hello there, I am new to Geant4. I am looking to draw only the contour of a cube.
I am starting by modifying the example B1. So far I was able to change the geometry of the detectors just fine. Now I am looking to set a cube in the center of the world volume but I do not need it to be a detector, simply a shape for visual reference. I am having trouble simply representing the vertices and edges of the cube.
If I do not want the volume as defined a detector do I have to define it a certain way inside the DetectorConstruction.cc file?? Or does it have to be defined elsewhere??
And to draw only the vertices and edges do I modify the definition in the .cc file or do I have to apply a certain command in the vis.mac file??
