I want to record ion kinetic energy, so first i need to query the particle is ion,
the code like this:
if(step->GetTrack()->GetDefinition()==???)
how to write ion definition?
the code like this:
Do you care which ion it is? If not, then you can test
if (step->GetTrack()->GetDefinition()->IsGeneralIon()) { ... }
(see G4ParticleDefinition.hh
). If you are looking for a specific nucleus, then you should put step->GetTrack()->GetDefinition()
into a local G4ParticleDefintion*
variable, and fetch atomic number and atomic mass.
Should it work the same as (step->GetTrack()->GetParticleDefinition() == G4Ions::IonsDefinition())?
