I am using Ubuntu 20…04.4 LTS and the version of geant4 is 10.07.
I am attaching the error file here.
error.txt (45.5 KB)
error.txt (45.5 KB)
Do you have the error running all examples?
I am guessing that your path to your geant4 download is not defined. Are you providing the DGeant4_DIR when you run cmake? The step before make
Yes I had provided that.
Now when I tried to run example B3a, the following error occurred while running configure in ccmake:
CMake Error at CMakeLists.txt:17 (find_package):
By not providing “FindGeant4.cmake” in CMAKE_MODULE_PATH this project has
asked CMake to find a package configuration file provided by “Geant4”, but
CMake did not find one.
Could not find a package configuration file provided by “Geant4” with any
of the following names:
Geant4Config.cmake
geant4-config.cmake
Add the installation prefix of “Geant4” to CMAKE_PREFIX_PATH or set
“Geant4_DIR” to a directory containing one of the above files. If “Geant4”
provides a separate development package or SDK, be sure it has been
installed.
Configuring incomplete, errors occurred!
Could you pls suggest what to do here to successfully compile the program?
