Sorry this may be related to other questions I already posted, but I’m trying to separate the questions so that they can be searched and referenced by other users.
I understand geantino is a virtual particle that does not interact with a material and it undertakes transportation processes only. I imagine it would be useful for debugging or troubleshooting. I also learned that there is a case where geantino is used as a placeholder in the constructor and replaced with a real particle later. Other than those purposes, I feel geantino should not be used for a real/physical simulation, as it doesn’t include any interaction with a material (not physical). That said, I am confused by the ‘\extended\radioactivedecay\rdecay01’ example, where all the particles and ions are treated as geantionos… Any thought?
Everything you say is correct here. The G4Geantino as such, is basically only useful for debugging G4Transportation (including with fields, as there are charged geantinos as well), and for getting geometry information (e.g., RayTracer uses them to collect all the boundary crossings along a direction).
I think the text you’re referencing with rdecay01 is meant to be shorthand. The physics list for that example includes only the radioactive decay process. It doesn’t include EM physics, hadronic physics, or anything else. So none of the particles produced are going to interact with your geometry. You’ll get the radioisotope decay you ask for, with the right kinematic distribution of daughters, but that’s all.
Rdecay01 is not meant as a realistic demonstration of radioisotopes in the world. It’s more like a “unit test” where you can see what the process does in isolation, with no other complications.
I am currently using rdecay01 code for developing one simulation of radon decay from soil to surface of the earth. So what should I do to get realistic simulation results since it uses geantino?
I am using physicslist.hh and physicslist.cc classes as it is in rdecay01 and I am confused how should I change it to get realistic results. but my detector construction class is ready with various soil layers and chemical composition of soil in the earth. basically I want to see how radon propagates through the soil from center of the earth to surface of the earth. How much radon particles reach to the earth if my particle gun is at center. That’s all I want to study.
1-It is a “trick” needed here. At the time when constructor of PrimaryGeneratorAction is invoked, the G4IonTable is not yet build: we cannot try to define an ion at this level. By default, Geant4 define a Geantino.
Therefore, if you do nothing with UI commands, the system enters in GeneratePrimaries() with a geantino. If so, we build Ne-24.
Of course, this do not happen if you have already define an ion with UI command : particleGun or GPS …
2- Anyway, I suggest you to read carefully Readme : rdecay01 is a special example where RadioactiveDecay process is registered alone.
For a ‘realistic’ simulation (eg. with more physics) , start with rdecay02 or one of the hadronic examples (Hadr06, Hadr07 …)
